20 Most Recent Samsung AQV36JA Classic 36000 BTU Single Zone Ductless Heat Pump Mini Split Air Conditioner System Questions & Answers
This type of unit is called a Mini Split Air Conditioner.
Hope that helps you check us out at Air Duct Cleaning
Samsung AQV36JA... | Answered on Nov 03, 2015
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Samsung AQV36JA... | Answered on Sep 28, 2015
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Samsung AQV36JA... | Answered on Jun 19, 2014
check the power cable between the two.
try in av mode with an external signal (like a dvd or homecinema)and if it work you must to change the mode function(maybe is select european mode or something else)
Samsung Heating... | Answered on Sep 20, 2019
E154 Error in Samsung Air-Conditioners If E1 and then 54 is displayed on the display panel after switching on the air-con, this indicates fan motor or capacitor is defective. Replacement is needed.
Samsung Heating... | Answered on Sep 14, 2019
Do you see any other digits alternating with the E4? Most of the error codes that I know with Samsung split system air conditioning units have three digits after the E. Depending on the last two digits, the error could be with the control board (printed circuit board), the fan, a sensor connected to the control board or the wiring. See https://removeandreplace.com/2017/08/15/samsung-split-system-air-conditioning-ac-error-codes-and-troubleshooting/ for some ideas.
I found the User Manual for the Samsung AQV24TWDN here: https://www.samsung.com/au/support/model/AQV24TWDNXSA/ . Scroll down or use the Download User Manual link. The direct link to the manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_AU&CttFileID=5078406&CDCttType=UM&ModelType=N&ModelName=AQV24TWDNXSA&VPath=UM/201401/20140107175828476/Australia_AQV30T@_IBIM_33367A_E_1.29.13.pdf&OriginYN=Y .
Please add a comment with the full error code for your air conditioner.
Samsung Heating... | Answered on Sep 09, 2019
Communication error
the inverter problem
Samsung Heating... | Answered on Aug 25, 2019
Samsung Split Air Conditioner Error Fault Code - E422
Definition Of Error Code: Outdoor unit EEV close 1 self diagnosis error
Page 4-41 of the manual at the link below:
https://www.dvmdownload.com/upload/product/118/download/AC030JN4DCH_4-Way%20Cassette%20NORDIC%20Service%20Manual.pdf
Samsung Heating... | Answered on Aug 21, 2019
Google (Samsung)(aqv24uwanxsa)(manual) without parens.
Samsung Heating... | Answered on Aug 15, 2019
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Samsung Heating... | Answered on Jul 05, 2019
Press 2nd f button and then beep off button
Samsung Heating... | Answered on Jun 08, 2019
Samsung AQV36JA Classic 36000 BTU Single Zone Ductless Heat Pump Mini Split Air Conditioner System Logo
Popular Tags
5 questions posted
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Heating & Cooling
Most Popular Question
kind unit
  • Heating & Cooling
