20 Most Recent
Sunbeam Humidifier. 3.23-Gallon Whole-House Humidifier SCM3609P-UM Questions & Answers
Need the manual for Sunbeam humidifier swm2311
El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
1/6/2023 2:32:03 AM •
Sunbeam...
Answered
on Jan 06, 2023
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
5/2/2018 9:35:34 PM •
Sunbeam...
Answered
on May 02, 2018
How to clean the fan in sunbeam humidifier
Go to Walmart and get Canned Air used to blow out debris from keyboards etc. Place the air tube near the fan vents and blow out debris. Keep the can up-right. Should you turn it upside-down, you will FREEZE everything, so do it correctly.
2/7/2018 9:03:52 PM •
Sunbeam...
Answered
on Feb 07, 2018
Why does my Sunbeam humidifier turn on but not work?
If the water valve from the water container to the misting head is defective, contains particles, or fails to open; then no activity will occur. Clean the system with Vinegar solution and be certain to use distilled or filtered water in the future.
2/7/2018 8:41:15 PM •
Sunbeam...
Answered
on Feb 07, 2018
My Sunbeam 705 Humidifier shut down.
Generally a shut down is due to an empty water container or the float valve. If you have a can of compressed air, you can blow dry the integral ports and perhaps free up any contamination that has caused the unit to shut down.
2/7/2018 8:27:26 PM •
Sunbeam...
Answered
on Feb 07, 2018
