20 Most Recent
Acer Veriton 3600 (V3600GT00150) PC Desktop Questions & Answers
How to turn on the crystal eye webcam of my
Perhaps this might help. I got this from a quick scan of this problem.
Basically you..
Click on Start>>>Then type in something like "crystal" into the
"start search" bar at the bottom of the start menu>>> Acer
Crystal Eye Webcam should then come up and then you just click on it to
use it.
V3600g video driver
Hi There,
Go to this link just select your model and operating system, then download and install the driver
http://support.acer.com/drivers_download.aspx
Enjoy
Theirs no indication where about to put the power
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Cant disable intrusion switch
Check on the version of your BIOS, This has been an issue with older BIOS software. You may have to update your BIOS to remove this issue. Also, some intrusion switches work on grounding a signal through the switch to show the machine is closed, by removing the switch, you have removed this signal, hence the bios will show the intrusion all the time. Try refitting the switch and taping it closed.
Is intel extreme graphic 2 an inbuilt video card?
Yes, Intel Extreme Graphics 2 is an integrated or onboard graphic/video chip on Intel 852 / 855 GM, GME, GMV chipsets for laptops. It is not a card which can be removed or replaced.
Hope this answers your query. Thanks.
Does anyone if the Acer Veriton 2.8GHZ Celeron
when you look at the rear part of your system unit, or even when you open the CPU Casing, you will see whether or not you have the Video card and Sound card. When you see expansion card inserted in the motherboard where your monitor's VGA cable is connected to, then you have a video card (external) but if your monitor connects to a VGA port which is connected to the motherboard, then you have an internal or built-in video card.
Sound cards are tested in similar ways but you have to look for the 3 holes (jacks) with color pink, green and yellow where you connects to your speakers and mic. if you look insode the CPU and a card is inserted there having those 3 ports, then your sound card is external, otherwise if it is directly connected to your motherboard then it is built-in sound card.
Software wise you will know what devices you have in your system.
Right click "My Computer" then click Properties
Click Hardware then click Device manager
I have an Acer Veriton 3600 Desktop and when I set
for the inbuilt speakers on the monitor you should see a plug in on the back part of the monitor that would fit a similiar plug that goes to your sound on the computer. you need a cord to from there to your computer. Second do NOT spray anything near the dvd rom as it may cause the dvd rom to stop working. first step is to make sure the dvd's are perfectly spotless when you use them as it may effect the rom working properly.
have you ever spilled anything on it ?
robert
Ethernet
if you you to the website of the ethernet card you can download the driver there easly done keep me posted please regards mike
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
