20 Most Recent Sunbeam Twin Electric Auto Heated Blanket- Mushroom BW9800-030-772 Questions & Answers
Hi I've had a heating blanket for about two weeks now and now it's flashing green light
Would be better if Make and Model was mentioned, but this says it is a grounding issue. https://www.google.com/search?q=heated+blanket+controller+is+flashing+green ..
11/21/2023 12:59:28 AM • Sunbeam Twin... • Answered on Nov 21, 2023
3answers
Can electrical cord for electrical blankets go between mattress and box spring
Wires should be on the floor. Do not put them where you may lay on them and or cause friction on them (even if it's just rolling over during the night).
9/21/2022 7:37:27 AM • Sunbeam Twin... • Answered on Sep 21, 2022
I need power controllers for my MODEL #2140 mattress cover.
Question moved from Car Accessories to one of the Electric Blanket categories. Almost impossible without a make name. That type of replacement only come from the manufacturer. Nothing is coming up on that model number. https://www.google.com/search?q=MODEL+2140+mattress+cover%2C+replacement++controller ..
11/30/2021 5:04:59 PM • Sunbeam Twin... • Answered on Nov 30, 2021
Can I plug it into a power strip?
12/9/2015 11:56:14 PM • Sunbeam Twin... • Answered on Dec 09, 2015
Control does not work. blanket will heat when using identical control. How do I get a control that works?
Try contacting the manufacturer for replacement. Or try fixing the one that does not.
11/23/2015 5:26:17 PM • Sunbeam Twin... • Answered on Nov 23, 2015
2answers
Power cord for the Sunbeam electric twin blanket
Haven't you contacted the company that shipped it to you? It might have been an oversight and they'll mail you one. You can do that for anything you get shipped to you from a company.
12/22/2014 4:34:37 AM • Sunbeam Twin... • Answered on Dec 22, 2014
When I plugged in the cord to the blanket, it displays a continuous blinking of the letter F
Sunbeams - blinking "F" means that the connection to the blanket was loose. Make sure you give it a good push to get the piece fully engaged.
11/26/2014 2:46:22 AM • Sunbeam Twin... • Answered on Nov 26, 2014
How do can you clean an electric blanket heating control where the dial is stuck and won't turn.
Wd 40 spray it down really good then wipe excess. Let dry
11/7/2014 11:11:25 AM • Sunbeam Twin... • Answered on Nov 07, 2014
0answers
Can a broken wire in a electric blanket be spliced
No . Get rid of it, they are not safe anyway.
1/5/2013 3:58:16 AM • Sunbeam Twin... • Answered on Jan 05, 2013
Sunbeam BL0750 electric blanket green light blinking
Sure, here are a few suggestions on where to find a replacement controller for your Sunbeam BL0750 electric blanket:
* **Sunbeam customer service:** You can contact Sunbeam customer service directly and they may be able to help you find a replacement controller. Their contact information is available on their website.
[Image of Sunbeam customer service website]
* **Online retailers:** There are a number of online retailers that sell replacement controllers for Sunbeam electric blankets. A quick search should turn up a few options.
* **Local hardware stores:** Some local hardware stores may also carry replacement controllers for Sunbeam electric blankets. It's worth checking with your local store to see if they have any in stock.
Once you've found a replacement controller, you can either install it yourself or have a professional do it for you. If you're not comfortable installing the controller yourself, you can take your blanket to a qualified electrician or repair shop.
Here are some additional tips for troubleshooting your Sunbeam BL0750 electric blanket:
* Check the power cord to make sure it's plugged in securely.
* Try using a different outlet.
* Check the fuse or circuit breaker to make sure it's not tripped.
* If you've tried all of these things and the blanket still doesn't work, you may need to replace the controller.
I hope this helps!
5/28/2023 7:35:05 AM • Sunbeam Heating... • Answered on May 28, 2023
Sunbeam Mix Master 10086659 (1970's ?) burning odor
There is chance that arcing brushes in the motor are causing the odor. They should be replaced and the armature cleaned. A sunbeam repair shop can refurbish your mixer if the parts are still available.
3/23/2023 3:51:32 PM • Sunbeam Heating... • Answered on Mar 23, 2023
Sunbeam Twin Electric Auto Heated Blanket- Mushroom BW9800-030-772 Logo
35 questions posted
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
control not work blanket will heat when
  • Heating & Cooling
