20 Most Recent
Initial IDM-1731 Portable DVD Player with Screen Questions & Answers
I put in a DVD and it says NO DISC.
1st, I think the term 'Expert' is used too loosely here, at least for me. LOL. I just had the pleasure of fixing an IDM-1731 with a 'No Disc' error. It just so happens that calibrating the drive helped me out.
For any of you that feel like taking a risk & opening up your player, I urge caution when handling the optical lens. There are 2 pots located above the ribbon on the end that connects to the lens to the left. The 1 on left I touched to the right & that helped me out. I'm thinking that the vibration caused the player to get out of whack as time goes on.
After getting the player to work, I took measurements with my multimeter. The left pot measures 3.06 k ohms & the right measures .965 k ohms. I hope this helps others out as it did for me.
I want to use the DVD player(IDM 1731), as a
It won't unfortunately. The ports on the DVD player itself are output only. You would literally need to open it up and solder input ports onto the board. I'm not sure how skilled you are in this particular area so I wouldn't recommend it. You can't just strip off one of the cables and connect them directly to the monitor because the internal board is responsible for maintaining power levels and recoding the source signal into something compatible for the monitor itself. I wish I had better news for you.
My daughter pulled white strip that is inside out how can i fix that
What I recommend you do is take a screwdriver and open the enclosure of the DVD played and look for the connecter port where the white strip was and can be connected to. But, I assume that you mean she pulled (Kids!?) the strip wire that is connected to the lens that reads the DVD's and the board of the DVD player. I have myself seen these connectors so that's what I recommend you do my friend. Hope this works and wish you luck.
Wanting to know if I
Try to check at the side of the unit if there is a audio video output, if there is, it is possible to add another lcd monitor.good day
