20 Most Recent Sanyo KS1271 11,900 BTU Ductless Mini-Split Wall-Mounted Cool Only Air Conditioner Indoor Unit Questions & Answers
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
8/23/2014 3:34:26 PM • Sanyo KS1271... • Answered on Aug 23, 2014
Indoor fan speed is low on sanyo mini split ks1271
If there's power to the fan coming from the relay, it's the fan motor.
8/30/2013 12:33:31 AM • Sanyo KS1271... • Answered on Aug 30, 2013
How do I set the time on a sanyo KHS 1872 air conditioning remote? not the timer but the time the clock?
the remote does not care what time it is. The AC unit has all the unit control's and info on it. Just like a tv remote the tv has all the info on it.
11/11/2022 7:05:41 PM • Sanyo Heating &... • Answered on Nov 11, 2022
How can I disconnect the heat on a Sanyo heating air conditioning wall unit 12000 but.
no info generic answer check and test thermostat and wiring circuit fan & heat should not be coming on when in a/c mode
8/18/2022 11:52:16 AM • Sanyo Heating &... • Answered on Aug 18, 2022
Sanyo ptac model# STW1223C2P no heat
Contact Sanyo directly to request the information.
3/29/2022 11:44:37 PM • Sanyo Heating &... • Answered on Mar 29, 2022
Service manual for Sanyo STW1223C2p
You can purchase the service manual from this website:- http://adfoc.us/60685483181460
3/20/2022 12:08:35 PM • Sanyo Heating &... • Answered on Mar 20, 2022
My sanyo wall heating and air unit wont turn off with it turned off
possible bad switch
1/20/2022 3:21:42 AM • Sanyo Heating &... • Answered on Jan 20, 2022
Need Access codes for a Polar Universal A/C Remote
polar 9045702 c?digo do LG
1/5/2022 9:18:31 PM • Sanyo Heating &... • Answered on Jan 05, 2022
4answers
This unit just installed...but purchased
Check for the correct voltage intake the capacitor needs to be replaced as its a very old ones need to be replaced by new one.
9/8/2021 1:23:15 PM • Sanyo Heating &... • Answered on Sep 08, 2021
2answers
Have a Sanyo KS2472 split inverter unit. On turning it on, operation light blinks and does not cool. Also compressor does not seem like it turns on outside. Please help.
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
7/30/2021 1:43:53 PM • Sanyo Heating &... • Answered on Jul 30, 2021
Sanyo air conditioner remote no longer controls my air conditioner
Hi Eugene, try replacing the remote control batteries You can do a test to see if your remote control is broadcasting Take your cell phone, put it in camera position and point the emitting LED of the remote control towards the camera, press any of the keys and see if you notice that a light emits, if so, the remote control is fine, if not, replace the remote control I hope you can solve the problem Regards Franco Dosil Hola Eugene, prueba reemplazar las pilas del control remoto Puedes hacer una prueba para saber si tu control remoto esta emitiendo Toma tu celular, ponlo en posicion de camara y apunta el Led emisor del control remoto hacia la camara, presiona cualquiera de las teclas y observa si notas que emite una luz, si es asi, el control remoto esta bien, si no, reemplaza el control remoto Espero puedas resolver el problema Saludos Franco Dosil
8/26/2019 3:51:54 PM • Sanyo Heating &... • Answered on Aug 26, 2019
Where can I get a filter for the sanyo khs0951 mini split a.c. unit?
https://lmgtfy.com/?q=khs0951+filter
8/25/2019 10:59:02 PM • Sanyo Heating &... • Answered on Aug 25, 2019
Sanyo new wick wont fit an yet they are tellimg me the model numb is right.
Could be the wrong part in the right box??? It does happen.
7/10/2019 12:44:27 PM • Sanyo Heating &... • Answered on Jul 10, 2019
One head of my 2 head sanyo mini split is blowing 80 degree air. The other head is functioning properly. There is only one condenser for both units. any ideas?
Possible, Refrigerant not flowing due to shut valves or solenoid problem.
Condensation cut off sensor also possible
7/3/2019 11:19:48 AM • Sanyo Heating &... • Answered on Jul 03, 2019
Sanyo C122C25 wall mount. Air and heat...just suddenly quit heating...power is on but blows cold air
If it is new split air conditioner with a four way valve and it stops giving heat. Check if there is any power going to the coil of the four-way valve. Check also the continuity of the coil. If there is power and the continuity, replace the four-way valve. If you don't get power going to the coil, check the wiring. If wiring is good, replace the electronic control board.
1/11/2019 3:31:47 PM • Sanyo Heating &... • Answered on Jan 11, 2019
Sanyo split system cut off on water sensor
The drain is plugged or the unit pump is not working. Check those two things
9/20/2018 5:27:42 PM • Sanyo Heating &... • Answered on Sep 20, 2018
Sanyo KS1271 11,900 BTU Ductless Mini-Split Wall-Mounted Cool Only Air Conditioner Indoor Unit Logo
2 questions posted
Top Sanyo Heating & Cooling Experts
Jay Finke
Jay Finke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Heating & Cooling
Most Popular Question
check correct freon level sanyo ks1271
  • Heating & Cooling
