20 Most Recent Frigidaire Fdl50s1 Air Purifier & Humidifiers Questions & Answers
I plug it up display shows 8.8. and goes blank. Power light on top and side is green ON. Full bucket light and alarm works, timer button works, nothing else works.
Hello Ethan, thanks for your submission! Based off what you have described your Frigidaire dehumidifier is displaying 8.78 after being plugged in. This could be an internal issue with a sensor or panel. You may need to contact your manufacturer for additional assistance. Good luck! -Matt
5/10/2016 4:29:07 PM • Frigidaire... • Answered on May 10, 2016
Frigidaire dehumidifier fdl50s1
plug it
10/1/2014 11:15:34 PM • Frigidaire... • Answered on Oct 01, 2014
Unit trips the breaker when turned on.
could be a lot of things, start capacitor on the motor, control cct etc etc needs an engineer, or use of a test meter to find fault
8/13/2014 7:26:01 PM • Frigidaire... • Answered on Aug 13, 2014
Frigidaire dehumidifier model # FDL50S1 clicking very loudly.
If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
8/27/2012 6:06:35 PM • Frigidaire... • Answered on Aug 27, 2012
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..pxl_20220505_200138238-xcwecsr4zo4tymj3g1gtyjri-d-0.jpg
9/14/2022 11:35:48 AM • Frigidaire... • Answered on Sep 14, 2022
Why won't the tank of a Frigidaire FFAD2233W1 dehumidifier stay in place in the base unit?
Question edited for clarity. Question moved from Spanish car company Seat (See-At). Is it less than a year old? You can claim on the warranty. The water bucket seems to have to parts that might snag, the handle and the float arrangement. It just slides in on two tracks. If there is no water in in, tip it onto its back and see if it is mis-tracked. https://na2.electroluxmedia.com/XL/Electrolux/Electrolux%20Assets/images/Product%20Photography/FFAD2233W1-F6_944.jpg?impolicy=dimensions&imwidth=1400 https://www.frigidaire.ca/Home-Comfort/Dehumidifiers/FFAD2233W1/ Stuck Bucket. https://www.google.com/search?q=frigidaire+ffad2233w1+dehumidifier+bucket+stuck ..
4/5/2022 8:39:49 PM • Frigidaire... • Answered on Apr 05, 2022
Can the grill of a 70 pint Frigidaire be removed to clean the coil?
With your unit switched off, vacuum them with a brush attachment. If still dirty, you can spray with a degreasant spray and then gently rinse with a towel under the coils. Dry with a hair dryer. That is how refrigeration techs do it.
12/25/2021 10:33:55 PM • Frigidaire... • Answered on Dec 25, 2021
My Frigidaire dehumidifier compressor runs constantly and will not turn off with the switch. Have to unplug the unit.. Everything seems to be working to dehumidify. Is this a bad motherboard?
Does it run after you get to the optimal humidity level? If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
10/12/2021 5:14:13 PM • Frigidaire... • Answered on Oct 12, 2021
I have a FO code on my Frigidaire dehumidifier. Cleaning filter does not help. About four years old. Need to open case and check for rust?
First, I'm not a Frigidaire tech. * Check your warranty. Call for service. * Contact (note Live Chat link); https://www.frigidaire.com/Owner-Center/Contact-Us/ *** following is for information only *** * Be sure to check the tub and filter (make sure they are seated properly.) * Checking basic problems; https://www.youtube.com/watch?v=SXJrVGP_Ixs * Review; https://www.youtube.com/watch?v=BbwIEU3zlG8 * There are no customer service parts in unit other than what was mentioned in the video. * Contact Frigidaire or your local Appliance store for service. Aloha, ukeboy57
8/16/2021 9:50:26 PM • Frigidaire... • Answered on Aug 16, 2021
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend, I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps. a. Remove the filter every two weeks based on normal operating conditions. b. To remove the filter, remove Bucket then pull filter downwards. c. Wash the filter with clean water then dry. d. Re-install the filter, and then replace Bucket. I have also included the link for your manual, where I found these instructions. Hope this is helpful. -Best Regards- WP Frigidaire Manual Search Results
7/7/2021 1:03:45 AM • Frigidaire... • Answered on Jul 07, 2021
Where can I buy a humidity sensor for my Frigidaire 70pt dehumidifier?
from or thru a dealer probably
6/5/2021 11:03:50 AM • Frigidaire... • Answered on Jun 05, 2021
Frigidaire washer dryer FEX831FS4. Washer worked fine. Put load in the dryer and started another wash. After about 10 minutes, both shut off at the same time. Didn't blow a fuse in the house.
i don't know. be careful with electricity. if possible, try running normal washer load along with your dryer but with [no heat] 'cold air only' to see if they will keep running. if they run OK, consider shutting off both washer and dryer. shut off main electrical panel and change fuses for both washer and dryer. turn hydro on and run both again with your normal settings. if they fail again please call for repairs. my dryer would not run and although everything looked and tested out OK, i had to replace a small 6x8" electrical box having 2 only 30 amp screw in fuses. then it ran OK.
10/2/2019 5:01:58 AM • Frigidaire... • Answered on Oct 02, 2019
How to set timer on Frigidaire dehumidifier model # KN70307736
it is in your manual. this site does not recognize the model u posted http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=KN70307736+&User=&Search=Search
9/14/2019 10:30:59 PM • Frigidaire... • Answered on Sep 14, 2019
Frigidaire Fdl50s1 Air Purifier & Humidifiers Logo
8 questions posted
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
plug up display shows 8 8 goes blank
  • Dehumidifiers
