20 Most Recent
Zanussi 18 in. DCS12W Free-standing Dishwasher Questions & Answers
Pump continues to be '****' and will not move to next cycle.....
HI only a suggestion please check your outlet hose for possible blockage by blowing down the pipe you will need a bit of force if you cannot then there is a blockage in the pipe, the programmer wont move until the water has been expelled first I hope that helps eric
Warning lights on front panel
Please try and drain off the water manually by releasing the drain from below , now open the door and check the DOOR switch. If this is faulty the program can get struck. Make sure the contacts of the switch is clean. Secondly check the pressure pump , if faulty this will not work to spray water. Finally the possibility of the program controller being a suspect cannot be ruled out.
Dishwasher dcs12w not heating up?
Just had this problem, I have a temp set up and found the drain was a bit to high. Put a bucket of water in to the machine and lowered the hose. It went through its cycle and emptied. now works OK, seems that it needed to empty to re-setrt the cycle. Worth a try
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat;
https://behealthyideas.com/
<ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM •
Zanussi...
Answered
on Jan 18, 2023
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM •
Zanussi...
Answered
on Nov 30, 2021
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
9/18/2021 8:05:04 AM •
Zanussi...
Answered
on Sep 18, 2021
