20 Most Recent Zanussi 23 in. ZDT6252 Built-in Dishwasher Questions & Answers
Too much soap use less soap
Zanussi 23 in.... | Answered on Mar 03, 2019
Does your dishwasher have a built in disposal?
Zanussi 23 in.... | Answered on Sep 10, 2017
A very common cause of this is the electric solenoid operated inlet valve failing in the closed position. So when it gets a "go" signal it does not open. The spare part is cheap, so most of the cost would be a service call.
Zanussi 23 in.... | Answered on May 03, 2017
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Zanussi 23 in.... | Answered on Oct 10, 2015
are the dishes spotty or cloudy? if so it is your hard water and not the dishwasher. go to www.dishwasherfilter.com and get their system. works awesome and guaranteed to solve your problem if the dishes are cloudy or have a white residue on them.
Zanussi 23 in.... | Answered on Aug 08, 2013
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Zanussi 23 in.... | Answered on Jan 12, 2013
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
77 questions posted
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dishwashers
  • Zanussi Dishwashers
Most Popular Question
reset zanussi zdt6252 dish washer
  • Dishwashers
