20 Most Recent
Soleus 10,000 Btu Portable Ac Air Conditioner Heater Dehumidifier Fan X-lx-100 Questions & Answers
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
I have a D70E A Soleus Dehumidifier that has begun making a rattling noise.
If it’s the one like move, vibration comes from the pump that takes reservoir water to be evaporated. Mine never seems to shut off and is noisy because there’s no water. And eventually it throws an e4 error saying that some water store is full. I can hear compressor come on nicely and quietly. I’ve cleaned the float switch area that was filthy. I was unable to easily remove and fully clean the inside of the donuts. Perhaps the funk is interfering with the float switch. Next step is to research these float switches for how they work. There in another float switch that is not connected anywhere, nor is there a place that it could connect to.
5/10/2020 6:51:11 PM •
Soleus...
Answered
on May 10, 2020
What does E5 mean on Soleus Air dehumidifier?
hi Randal.
this is all i could find on the internet.
Your dehumidifier has sensors to monitor for various conditions that may prevent the unit from operating in a normal manner
problem,the led display is showing e5, possible cause,over current protection..solution.unplug for 10.minutes then turn on the unit and if the e5 is still showing contact customer services or a dealer.
you could try this link as well to see if its of any help to you.
What does E5 mean on Soleus Air dehumidifier Google Search
12/3/2017 5:22:27 PM •
Soleus...
Answered
on Dec 03, 2017
