20 Most Recent
Zanussi 18 in. ZDT5052 Slim-Line Built-in Dishwasher Questions & Answers
Below the filter the dishwasher
Do you have a garbage disposal? There is a vent in the tube that runs to the sink that can get blocked. There is also a screen or filter in the bottom of the machine that can get clogged. The pump can get jammed with debris as well.
Many dishwasher clogs are caused by food and
drain particles siphoning back out of the drain or garbage disposal and
into the impellor of the dishwasher drain pump. Remedy this situation
the drain hose has to be long enough to loop up to the underside of the
countertop then back down again to the drain connection, this should
stop the siphoning effect. Also, if you already have the anti-siphoning
device installed (usually on sink a chrome cylinderically cap) also
called a "air-gap". Remove the cap by pulling off and check that it is
not clogged up. If you do not have one and you have extra hole that is
capped on your sink you can install one.
Another possible can is that your drainage screening is clogged, if so
clean it. Or the drainage screen is missing or not seated properly
causing food particles to jamb up the drainage pump impellor. These
impellors are plastic and it does take much to stop one.
It won't fill with water
Water valve is locked out. a blockage in some sython tubes may be the cause .remove drain screen remove single screw on a domed plastic cover ,take out and clean the u shaped tubes(note the correct positions).take off the water inlet pipe to remove water pressure to valve (to unlock it) fit all the parts back and try it. if it wont work the blockage is beneath the tubes in a short tube(10" ) in the base below sython tubes.
Some 1 gave my daughter a slimline zanussi
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
www.appliancehelponline.com
Hope this helps.
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat;
https://behealthyideas.com/
<ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM •
Zanussi...
Answered
on Jan 18, 2023
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM •
Zanussi...
Answered
on Nov 30, 2021
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
9/18/2021 8:05:04 AM •
Zanussi...
Answered
on Sep 18, 2021
