20 Most Recent Emerson Lennox Ducane Armstrong Furnace Blower Motor K55hxkpy-9740 Questions & Answers
3answers
Why is it whining and humming?
Sometimes a louver on the squirrel cage comes loose maybe from taking it apart...hand test every louver. You may find that you need a new one.
8/2/2021 7:43:48 AM • Emerson Lennox... • Answered on Aug 02, 2021
2answers
Why does the furnace blow 5 amp fuses?
Its drawing much to high amperage on startup. It may be dirty, unmantained, blocked with something, or a bad run capacitor. Likely, at this stage, it needs replacing. If its belt drive, be sure you have the proper slack and the bearings, if needed, are oiled and not faulty.
11/4/2015 12:26:31 AM • Emerson Lennox... • Answered on Nov 04, 2015
My ducane furnance blower wont ignite the thermost t keep going off
The blower requires proper voltage, I will include a diagram however if not familiar with power I advise against trying any repairs. 23720366-wil0gxehsfojcry3vcxysbjd-5-0.png
3/24/2015 8:59:01 PM • Emerson Lennox... • Answered on Mar 24, 2015
2answers
Is 32c a normal temp for an exhaust on a force air high efficiency house furnace? This is the air temp that goes outside after heating the plenum. Is there a lot of heat going up the "chimney"??
Any furnace providing heat where it should and has little to no heat from its exhaust is doing a GREAT job ;-) Our high efficiency gas furnace was installed with a PVC pipe as a 'chimney' which bothered me to no end until I found the surface temp of that plastic pipe only barely warm to the touch- that is a home run!
1/30/2015 7:42:56 PM • Emerson Lennox... • Answered on Jan 30, 2015
2answers
THE DRAFT BLOWER IS TURNING ON BUT NOT FIRING UP WORKING ALL DAY STOPPED OVERNITE
The induced draft motor has a induced draft proving switch that is a pressure switch , it resembles a silver round flat device about 4 inches across with 2 wires, it will have a tubing attached to it that also is attached to the induced draft assembly housing on a barbed port, this is how the induced draft is "proven" thus giving the A OK to go to the next sequence of operation which is ignition trial period, it will attempt a ignition sequence for about 30 seconds 3 times before it will lock out if it has a circuit board, if so a flashing code will be observed and the legend in the back side of the blower door will tell you the codes meaning. What is wrong 80% of the time is the barbed port on the induced drafts assembly is obstructed by carbon and not allowing the pressure switch to "sense" / prove the induced draft motor is running. You can connect the pressure switches 2 wires after the induced draft begins, this simulates a operational pressure switch and should begin the ignition phase if all is well, otherwise if all safety's or high limits are closed, then the ignition module is bad. This is for spark type, if you have a hot surface ignitor look to se if its broken or cracked or has a burned spot visible, if not try testing for 120 volts to it, if you read proper voltage, then the hot surface igniter is bad. 25360510-wil0gxehsfojcry3vcxysbjd-1-0.png
1/30/2015 7:39:02 PM • Emerson Lennox... • Answered on Jan 30, 2015
Wireing diagram for lennox G8R furnace
1/13/2015 1:27:05 PM • Emerson Lennox... • Answered on Jan 13, 2015
Lennox furnace fan runs constantly
bad fan limit
11/26/2014 3:51:22 PM • Emerson Lennox... • Answered on Nov 26, 2014
What is the blue resistor on the right side between the black squares on a 30w25 Lennox ignition control board
I would buy another board. The boards contain safety features.
9/28/2014 10:35:26 AM • Emerson Lennox... • Answered on Sep 28, 2014
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
2/27/2014 1:03:15 AM • Emerson Lennox... • Answered on Feb 27, 2014
Heater heats but shuts off
Try the fan in the ON position on the thermostat, do you mean the fire shuts off or the blower? a395e602-38d7-412e-a553-23ee69e9350b.png89346502-1e77-4384-8244-ea6d6788bd04.png09d1472e-35ed-4d26-be81-011af0d56f26.png
12/14/2013 6:16:03 PM • Emerson Lennox... • Answered on Dec 14, 2013
Need a wiring diagram for armstrong air model
12/14/2013 6:06:32 PM • Emerson Lennox... • Answered on Dec 14, 2013
0answers
Lennox blower run continiuslly
Limit switch. Call a technician :)
11/5/2013 10:44:13 PM • Emerson Lennox... • Answered on Nov 05, 2013
I have an Armstrong SX Ultra 90 propane gas
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
10/20/2013 3:07:36 PM • Emerson Lennox... • Answered on Oct 20, 2013
0answers
I have an old lux500 thermostat in replacing it with Emerson sensi touch smart thermostat. Do I need to change any wiring?
Probably, see the wiring directions, or call an HVAC technician.
11/1/2023 8:16:19 PM • Emerson Heating... • Answered on Nov 01, 2023
2answers
Changing thermostat from old Lux 500 to Emerson sensi touch smart thermostat. Is the current wiring compatible with both?
you are the only one who knows how many wires you have and hvac. here is the manual and you can look at wiring diagrams. https://www.luxproducts.com/wp-content/uploads/2017/07/tx500_manual_en.pdf
10/29/2023 9:00:14 PM • Emerson Heating... • Answered on Oct 29, 2023
Emerson thermostat 1f88ez-0251 Flame icon is flashing how do I fix this?
you can lower temp setting ,or leave it alone it is normal here is a link to instructions copy and paste https://climate.emerson.com/documents/thermostat-1f86ez-0251-instructions-es-es-1570244.pdf ..
2/4/2023 3:03:55 PM • Emerson Heating... • Answered on Feb 04, 2023
What does it mean when flame icon is flashing on an Emerson thermostat?
The Flame icon ( ) will display flashing to indicate that the Aux system is operating. Press to adjust the thermostat below room temperature. The Aux heating system should stop operating.
2/4/2023 3:00:39 PM • Emerson Heating... • Answered on Feb 04, 2023
Emerson Lennox Ducane Armstrong Furnace Blower Motor K55hxkpy-9740 Logo
20 questions posted
Top Emerson Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Heating & Cooling
Most Popular Question
whining humming
  • Heating & Cooling
