20 Most Recent Zanussi IZ12 Front Load Washer Questions & Answers
Machine retains water
Hi, Please check the small thin rubber pipe that is connected to the drum. it acts as a pressure sensor may be it is clogged and not able to give proper water level reading. use skewer or thick flexible wire to clean it.
10/3/2017 2:24:21 PM • Zanussi IZ12... • Answered on Oct 03, 2017
2answers
Error messages displayed on my zanussi iz12
e40 the door not been closed e20 the drain hose may be kinked
7/6/2015 8:57:07 PM • Zanussi IZ12... • Answered on Jul 06, 2015
2answers
Error e51 on zanussi iz12
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
7/6/2015 8:14:50 PM • Zanussi IZ12... • Answered on Jul 06, 2015
0answers
Don't start
Be the first to answer 2/19/2014 3:04:02 AM • Zanussi IZ12... • Posted on Feb 19, 2014Be the first to answer
0answers
0answers
2answers
Fabric conditioner does,nt go into drum.
You need to remove the dispenser from the washer completely, and clean every bit of it completely give it a thorough wash and make sure that every bit is clean.
Get a strong thin piece of wire, and make a hook in the end, and then poke it into every hole in the top of the dispenser compartment to make sure none of the holes are blocked up.
This should solve the problem
Plz rate my solution.Thanks.
8/2/2013 9:52:42 AM • Zanussi IZ12... • Answered on Aug 02, 2013
0answers
0answers
No water coming into machine
First check that there is water coming into the pipes to the watervalve the machine is connected to .Second, check that the hoses aren't kinkedIf that doesn't solve it, your inlet valve assembly is probably bad.
5/12/2012 2:01:01 AM • Zanussi IZ12... • Answered on May 12, 2012
Zanussi IZ12 Front Load Washer Logo
73 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
good evening zanussi iz12 washing
  • Washing Machines
