20 Most Recent Coleman Dc 12 Volt Inflate-all Pump Questions & Answers
try grabbing it with pliers. sounds like it is corroided
Coleman Dc 12... | Answered on Aug 03, 2017
since it is such a small and simple device there may not be one available. Call Colemans customer service, toll free at
800-835-3278 Be prepaired to tell them the model number of your pump, it should be something like 2000000350
Good luck. (What is it you are looking for)
Coleman Dc 12... | Answered on Mar 30, 2014
If the shaft from the motor is not securely connected to the fan, although it is turning, it may be slipping. Check that the set screws are tight between the motor shaft and the squirrel cage fan.
Otherwise, it sounds like you have duct problem. A rodent may have chewed a hole in the duct, or the connection between the and the delivery duct, or the connection between the delivery duct and the floor or wall grate has become disconnect. (This last is common, a screw holding the duct to the floor grate has come loose or the duct tape has come loose from gravity pull down on the duct to grate connection. If you have a basement or crawl space you have have to inspect that the duct work has not come apart.
Coleman Heating... | Answered on Aug 17, 2019
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Coleman Heating... | Answered on Jul 15, 2019
many times the ratings will be on the compressor and fan motor themselves. check data plates, if available, for mfd ratings
Coleman Heating... | Answered on May 16, 2019
That’s a model number for a mobile home furnace. The flame sensor is inside the burner chamber. You have to turn the gas off, remove the screws that hold the two plates around the gas valve, and pull the whole burner assembly out. Be careful of the igniter, and don’t use sand paper on the flame sensor ??
Coleman Heating... | Answered on May 09, 2019
you need to download the t6 installation manual. enter the isu menu and set up the tstat to control a heat pump.
Coleman Heating... | Answered on Apr 28, 2019
Coleman Dc 12 Volt Inflate-all Pump Logo
11 questions posted
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Heating & Cooling
Most Popular Question
remove battery
  • Heating & Cooling
