20 Most Recent Drive Medical Spitfire Travel 4-Wheel Power Scooter Blue Questions & Answers
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Drive Medical... | Answered on Oct 25, 2014
Hi u don't mention the problem
rear axle assembly is very reliable not prone to failure,
CHECK YOURE TYRE PRESSURE 30 to 35 .
also tighten rear axle NUTS VERY TIGHT loose nuts can cause a
thumping noise........cheers
Drive Medical... | Answered on May 08, 2019
SADLY WE HAVE NO IDEA THAT WILL HELP YOU . HAVE A FRIEND CHECK IT WITH YOU
Drive Medical... | Answered on Mar 06, 2019
What was the question? and have you tried asking the manufacturer or where you purchased the chair> Hope you get an answer soon
Drive Medical... | Answered on Mar 03, 2019
Best bet is to contact manufacturer and get their advice, make sure they tell you how to fix it and not persuade you get a new one.
Buy tazzle 20 FM Online strip is Manufactured by Dr. Reddy Lab. Tazzle 20 mg Online is contain of Tadalafil. Buy generic drugs from this Trusted online pharmacy Medypharma, get great discounts and Free home delivery on Order above $249 ! tazzle 20 mg online, tazzle 20 mg review.
Drive Medical... | Answered on Feb 27, 2019
Buy Imbruvica 140mg Online Capsule is used in the treatment of mantle-cell lymphoma and blood cancer. Imbruvica 140 mg price in india, side effects, reviews, price, Manufacturer, chemotherapy. Imbruvica Tablet. Order Now.
Drive Medical... | Answered on Feb 18, 2019
Sounds like a battery connection at the positive or negative battery terminal itself. Do you have a service plan or warranty, what brand is it?
thanks and don't stress as it'll be fine, it's something simple
Drive Medical... | Answered on Jan 28, 2019
hi, count how many bleeps a pause then it repeat . Then i can start to help you.
Regards
Drive Medical... | Answered on Jan 20, 2019
Hi Ray, i suggest you check them again, that 's a classic fault,
Regards
Rob
Drive Medical... | Answered on Nov 17, 2018
Drive Medical Spitfire Travel 4-Wheel Power Scooter Blue Logo
1 questions posted
Top Drive Medical Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Sheldon Dedek
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Drive Medical Health & Beauty
Most Popular Question
light blinking 7 fault code fault code
  • Health & Beauty
