20 Most Recent
ASUS PCI-L3C920 Network Adapter Questions & Answers
My computer can't find the
1. Sometimes it fails to initialize, and a simple restart would fix it.
2. If a restart didn't fix it, go into Device Manager and see if it appears on the list, under Network or Other.
2a. If it does, try reinstalling the drivers for it.
2b. If it doesn't, turn off the PC, and reseat the network card in the slot.
3. If it's onboard, and can't be reseated, you might have to buy a new network card.
I My network controller, ethernet
this yellow question mark indicates that you device driver are not installed properly or not functioning.
so kindly right click on that yellow and select the update driver and put the asus motherborad cd in the cd-rom and than click next on to install drivers automatically from the cd.
Rest Assured
Vipin
Ethernet controller with big yellow question mark
You need to reinstall the software for that, if its a ethernet card built in to your motherboard you can find the software for it from the motherboard setup CD , and if its a additional device to your computer just run the setup CD for it to reinstall the software back....
Network adapter
1) The first step you can try by checking from device manager whether its showing the device over there or not. Just click on Start and type there "devmgmt.msc". Under network adapters or in other devices if you are able to see any device which state as network adapter it means its getting detected. If not!!!
2) Check by changing the slot of the adapter and insert it any other slot in your computer..
3) If it still doesnt work then if posibble can check this adapter with any other computer as well
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
