20 Most Recent
ASUS SiS Chipset P4S133 (P4S133/PA/LAN) Motherboard Questions & Answers
Motherboard driver p4s133 please!
if you are having trouble
with your drivers
here is a general look at the
drivers and how to update them
if your computer came with
a motherboard disc the drivers could be on it
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver hope this helps
Where to plug in start button wires, i have nothing on the screen
here is a direct link to the motherboard manual that will have the pin layout for the power and reset switches on your case: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4s133/e1025_p4s133.pdf
just plug the labeled wires coming from the front of th case into the pins shown in the manual and if the power switch still doesn't work try reversing the way it is plugged into the pings (switch the positive (+) and Negative (-)) and then try it again.
Pc does not boot
hi i think you need to check your bios cus when your take out the battery the bios resets see if the first boot is set on your hard drive on my pc it is set on hdd 0
P4S133 bios settings...
Check the jumper for the bios, it may be set for clear. (not an uncommon boo - boo). Move the jumper back to default pins.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
