20 Most Recent ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/ VGA/ AUdio/ LAN/ MATX (GXMBP4P800VM) Motherboard Questions & Answers
My asus p4p800vm motherboard doesn´t
If it's Windows 7 and up alter Bios to boot from Usb install from Flash Disk, use... http://wintoflash.com/home/en/
9/3/2017 1:21:50 PM • ASUS P4P800-VM... • Answered on Sep 03, 2017
P4p80 vm - usb 2.0 help
It might be on a different usb port . Some computers have different ports like one will be usb 1 and another will be usb 2 . Check for other usb ports on the computers outer case and try them all.
3/30/2017 11:06:17 PM • ASUS P4P800-VM... • Answered on Mar 30, 2017
Vga graphic card not found
Sounds like the VGA driver may be corrupted or has not installed correctly.Go to 'Device Manager (as an Administrator), Find your graphic card in the list, Uninstall it by right clicking, Then restart your computer.The VGA driver will reinstall itself automatically as the computer restarts.
10/28/2013 4:46:37 PM • ASUS P4P800-VM... • Answered on Oct 28, 2013
4answers
Lan drivers
to download lan drivers
9/25/2012 2:47:37 PM • ASUS P4P800-VM... • Answered on Sep 25, 2012
When I plug my computer up nothing comes on but
This is really poor practice and an excellent way to destroy a motherboard.
You should always have the board connectors plugged in before turning on the power supply, otherwise you may be blowing ICs left and right. It's perfectly OK to plug the supply into the wall or turn on its power switch with the board connectors in place. Also, nearly all modern boards have a set of pins that go to the front panel 'power' switch which does not switch AC but sends a logic signal to the power supply to turn the rest of the voltages on. Those pins have a 5V potential on them that is typically grounded to tell the supply to turn on.
If you're lucky, you still have an undamaged motherboard.
8/28/2011 8:56:28 PM • ASUS P4P800-VM... • Answered on Aug 28, 2011
I get this Chassis Intrusion
You may want to check to have good closed the chassis of the computer. Some of the pcs have intrusion system detection and if the chassis is not correctly closed you get that message
8/21/2011 11:59:49 AM • ASUS P4P800-VM... • Answered on Aug 21, 2011
2answers
Trying to set up new motherboard. when i open the
This problem usually that battere is exhausted, Try to change battere with the new one.
7/3/2011 2:02:33 AM • ASUS P4P800-VM... • Answered on Jul 03, 2011
Hello, my main board is
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
1/6/2011 12:19:46 AM • ASUS P4P800-VM... • Answered on Jan 06, 2011
0answers
Saya pake mb p4p800vm, tapi
http://www.driverstock.com/ASUS-P4P800-VM-driver-download/6-9-10025/index.html
10/14/2010 2:32:43 PM • ASUS P4P800-VM... • Answered on Oct 14, 2010
Sound card isue
This model has premium onboard sound. The driver available from ASUS is for this onboard sound capability. It does not have a "card" - if you are trying to install a sound card in the expansion slot, I would recommend taking it out.
You did not specify your OS. The latest ASUS sound driver is available here:
Choose OS
Click [+] next to audio
Download driver
http://usa.asus.com/product.aspx?P_ID=lWkFWt6I1Nykye1b&content=download
12/16/2009 6:45:54 PM • ASUS P4P800-VM... • Answered on Dec 16, 2009
3answers
P4P800 SE vs P4P800 Mx
The general answer is yes.
1) Both of these boards have the same CPU socket:
"Intel Socket 478", so they are CPU compatible
at the pin level.
The different support chip-sets (North and South bridge)
do provide different I/O features and bus optimizations,
but this is NOT a problem to the CPU, nor an issue to
worry about.
2) Also, both these boards are smart enough
in the BIOS, to automatically detect the CPU
and to automatically set the clock speeds and
power supply voltages.
The P4P800 board is more then fast enough to take full
advantage of the 2.4 GHz CPU.
The only time you could get into trouble is if you
override the BIOS settings to over-clock or over-voltage
the CPU or memory, without knowing what you are doing.
3) If you are not sure, just let the BIOS do its thing, and auto
set the CPU and memory settings.
However ! ...
4) Be extremely careful when physically swapping the CPU's
and heat sinks:
a) Make sure the computer is physically unplugged,
and the power has been off for a few minutes.
b) Unclip the whole fan/heat-sink assembly as a unit if
you can, and wash the bottom of the heat-sink with
rubbing alcohol to remove the "white gunk"
(heat-sink transfer compound)
Similarly clean off the CPU's after you remove them from
the socket, do NOT drip alcohol onto the mother-board,
because it could dissolve, soften or contaminate it.
The alcohol will NOT hurt the metal heat-sink, nor the
ceramic top of the CPU.
c) To remove the CPU from the socket (and to replace it)
release the socket lever on the socket FIRST.
The CPU should slide in and out of the socket without
ANY force what so ever, and make sure that PIN-1
and the shamfered corner are oriented correctly !!!
If you plug in the CPU the wrong way, and power it up,
it is GAME OVER !!!
d) Take extreme care not to STATIC zap the mother board,
or the CPU. Wrap a thin bare wire around your wrist,
and connect the other end to the computer case,
before handling ANY electronic parts.
(With the computer still turned off and unplugged :)
This is EXTREMELY important, because your body
can accumulate a very small charge at a very high
voltage of several thousand volts before you even feel
a tingle, and when discharged can fry or injure every
chip on the board.
do NOT remove the mother board from the box just
to change the chip, if you can possibly avoid it.
Handling motherboards is ALWAYS risky due to
the risk of static as well as flexing the board and
braking internal "plate-through-hole" connections.
I am an expert many times over so please take my
word for it.
5) After you install the new CPU in its socket, but BEFORE
you re-attach the heat-sink, you need to apply a liberal
amount of NEW white heat-sink compound between the
heat sink and the CPU.
This white goo is a silicon based grease that drastically
improves the heat transfer from CPU to heat sink, i.e.
lowers the thermal resistance in degrees per Watt,
to keep the CPU from overheating.
Many people skip this important step, but if your CPU
overheats, it won;t last long.
The heat-sink compound is available from any electronic
or computer shop.
6) Make sure that you clean and reconnect the CPU fan,
and check that it is working properly.
7) Make sure that your power supply is strong enough to
provide the additional current required by a faster CPU.
Keep in mind, that the amount of power consumed, and
heat generated by the CPU is directly proportional to
frequency and to the square of the operating voltage.
Also, faster CPU's never last as long as slower ones,
due to increased nano-scale current densities and
atomic scale erosion due to these currents. Although
the currents are miniscule from our point of view, so are
the circuit geometries, and if you do the math, (I have)
the effect of sending some of these internal currents
through the nanometer-sized conductors is like forcing
the Mississippi river through a half inch pipe.
The sheer momentum of the electrons is sufficient to
knock whole atoms out place and slowly erode the
tiny semiconductor structures.
All chips WILL fail in time. The faster they run the sooner
they fail, but hopefully "after" they become obsolete.
8) So make sure you have enough fans to keep things cool.
9) Finally it is good to identify your speed bottle necks,
before you start changing things, for example:
If the RAM is marginal, it will not run reliably at the
increased bus speeds. The mother board (BIOS)
compensates for this when calculating the timing
settings, and increases the number of bus-cycle wait
states. The net result is that your faster CPU can result,
in a slower computer under some conditions.
Another thing people tend to ignore is the amount of RAM.
RAM is 10,000,000x faster then hard disk.
When a computer (Windows) starts running out of RAM,
it begins to swap less used data to hard disk, in a process
called virtual memory paging. If it pages too much, it is
called thrashing. A thrashing computer can take hours or
even days to perform a task that should only take a few
seconds.
Increasing the speed of the CPU by 20% often doubles the
cost. The same amount of money is put to better use
increasing the amount (and quality) of RAM, with much
more impressive results.
For a Pentium-4 based XP machine I recommend 2 Gigs
of RAM, only because 32-bit Windows can only access
4-Gigs, 2 of which are reserved for the OS and remapping
the video card. This leaves 2 Gigs for user app's.
IT is possible to configure windows to use a little more, by
setting the /3GB or the /uservalu= switch within the boot.ini
file but this can lead to unforeseen complications.
The problem with 64-bit windows is that it still has limited,
driver support and you need a 64-bit motherboart/CPU
such as a core-2-duo.
Good luck, please rate my answers.
Martin
11/4/2008 5:19:55 PM • ASUS P4P800-VM... • Answered on Nov 04, 2008
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/ VGA/ AUdio/ LAN/ MATX (GXMBP4P800VM) Motherboard Logo
15 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
saya pake mb p4p800vm tapi
  • Computers & Internet
