20 Most Recent
ASUS A7V333 Motherboard Questions & Answers
How to set boot priority in award modular bios v6.0
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
hope this helps
After replacing on board lithium cell, computer
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
At boot-up I get "invalid
1) Go into your bios by pressing the Delete key.
2) Navigate to boot disk priority.
3) Set this to Primary master disk drive (The drive that your operating system is installed on.
4) The save and exit.
This should stop the message from coming up and solve your problem.
Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
Thanks.
My audio not install.what can i do?
Hi thebigbumble,
I'm not sure why your audio is not installed, but you can download the driver to install it
HERE. Make sure you put in your model and operating system, and they will get you the right stuff.
Good Luck,
Please don't forget to leave a rating
Thanks
Mark
Hardware monitor found an error
First I would make sure all the power plugs are properly plugged into the motherboard and all other devices.
If that does not solve it then I would get the Power supply tested at a local PC shop. Or just get a new decent power supply. Looks like the Power supply without a doubt is defective.
No boot up
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
