I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
9. anonobomber, 07-05-2002 09:51
read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check
http://www.asus.com.tw for the manual pertaining to your motherboard"
