20 Most Recent ASUS P4V8X-X Motherboard Questions & Answers
11answers
Sata hard disk drive on asus p4v8x-x motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
7/18/2016 3:31:49 AM • ASUS P4V8X-X... • Answered on Jul 18, 2016
manual
0answers
ASUS P4V8X X SATA RAID
tankyou
10/5/2012 2:30:58 PM • ASUS P4V8X-X... • Answered on Oct 05, 2012
How to install driver to sound card
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you dont have a motherboard disk you will have to download the drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it righthope this helps
9/4/2012 4:34:05 AM • ASUS P4V8X-X... • Answered on Sep 04, 2012
Asus p4v8x-x bad bios checksum checking
Hi, you can download the bios file here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4V8X-X&p=1&s=15
Please select your windows version.
Select bios and click on global for download.
You have to unzip the file before you install it.
You might have to change the cmos battery out with
a new one:
ghost2233_59.jpg So the bios can remember its settings.
Thats why you get a bad bios checksum.
A reminder flashing the bios with a wrong one WILL destroy the mainboard.
9/12/2011 4:45:34 PM • ASUS P4V8X-X... • Answered on Sep 12, 2011
I have a asus p4v8x-x
Hi, you can download a manual here:
Please select your operating system.
Select manual and click on global for download.
Unzip the file before you can read it.
Maybe its just a setting in the bios that does that.
8/28/2011 4:10:26 PM • ASUS P4V8X-X... • Answered on Aug 28, 2011
2answers
Download card sund asus p4v8
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.if these arent right you will find free sound drivers http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need hope this help you
8/26/2011 3:16:20 PM • ASUS P4V8X-X... • Answered on Aug 26, 2011
Where can I find audio driver for win xp 2000 pro
You can download the audio and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
8/26/2011 11:54:26 AM • ASUS P4V8X-X... • Answered on Aug 26, 2011
My computer don't turn on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
7/15/2011 3:32:08 AM • ASUS P4V8X-X... • Answered on Jul 15, 2011
2answers
Raid controller drivers
download program ,driver genius,, then update drivers manualy, then the programm will download all that drivers you need.
5/30/2011 4:07:55 AM • ASUS P4V8X-X... • Answered on May 30, 2011
3answers
Re my Asus MB, P4V8X-X
Go to asus's website, they have drivers for all of their motherboards including sound, Your hard drive could be going bad if the files just disappeared, if you cant find the drivers it would probably be cheaper to buy a 10$ sound card and bypass the issue rather then fixing the motherboard.
5/2/2011 6:10:22 AM • ASUS P4V8X-X... • Answered on May 02, 2011
Bad bios checksum..my cd rom could not detect or
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd rom then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if your computer came with a motherboard disc the sound drivers could be on it if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
4/13/2011 2:36:59 AM • ASUS P4V8X-X... • Answered on Apr 13, 2011
Asus p4v8x-x bad bios checksum checking for
This problem could be caused by a near flat BIOS battery. Replace the BIOS battery and go into the BIOS configuration and set the Date and Time etc.
4/12/2011 4:47:59 AM • ASUS P4V8X-X... • Answered on Apr 12, 2011
Need raid contoller drivers for
http://majorgeeks.com/DriverMax_d5260.html Win7/Vista/XP . DriverMax is a new tool that allows you to download the latest driver updates for your computer. No more searching for rare drivers on discs or on the web or inserting one installation CD after the other. Just create a free account, log in, and start downloading the updates that you need.
You can also export all your current drivers (or just the ones that work ok) to a folder or a compressed file. After reinstalling Windows you will have everything in one place!
Most of the situations when Windows is running slower are caused by faulty driver installations. Windows stores all versions of older drivers just in case you want to go back; sometimes it messes up older versions with more recent ones. The Export Wizard will only export the drivers you select by copying the needed files to a folder or a compressed ZIP file.
After reinstalling Windows all drivers will be back in place in less than 5 minutes - sparing you of searching, inserting disc after disk and losing precious time. The Import Drivers wizard allows you to install all the drivers that you exported earlier. The entire operation might take up to 5-10 minutes.
Just one single computer restart will be required after all drivers are reinstalled!
DriverMax is able to display a complete report of all drivers (versions, release dates) installed on your system. This feature can also be very useful when you want to analyze the differences between the drivers installed on different machines. Hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/nvidia-raid-driver-zip/3000-18492_4-158932.html This package supports the following driver models: NVIDIA NForce(tm) ATA RAID Class Device
  • NVIDIA NForce(tm) ATA RAID Class Controller
  • NVIDIA nForce2 ATA Controller (v2.6)
  • NVIDIA nForce3 Parallel ATA Controller (v2.6)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.6)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.6)
  • NVIDIA MCP2S Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
  • NVIDIA nForce3 250 Serial ATA Controller (v2.6)
  • NVIDIA nForce 2 ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel ATA Controller (v2.5)
  • NVIDIA nForce 3 Parallel-Serial ATA Bridged Controller (v2.5)
  • NVIDIA MCP2S Serial ATA Compatible Controller (v2.5)
  • NVIDIA MCP2S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Parallel ATA Controller (v2.5)
  • NVIDIA CK8S Serial ATA Controller (v2.5)
4/11/2011 10:20:55 PM • ASUS P4V8X-X... • Answered on Apr 11, 2011
I want the asus p4v8x-x Support CD.... pls upload
You can get this from their website
3/19/2011 5:32:59 PM • ASUS P4V8X-X... • Answered on Mar 19, 2011
Bad bios, iwant to get
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
3/19/2011 4:57:14 PM • ASUS P4V8X-X... • Answered on Mar 19, 2011
3answers
I cannot format the computer because the
The CD is needed to install the drivers for the motherboard all the other utilities on it you can manage without. A getaround for you is to perform a backup your drivers onto a cd or USB memory stick and you can go ahead with your reformat.
3/19/2011 4:28:04 PM • ASUS P4V8X-X... • Answered on Mar 19, 2011
I don'n have driver for my ASUS P4V8X-X driver.I
Yo can get the drivers here.
2/24/2011 8:15:15 PM • ASUS P4V8X-X... • Answered on Feb 24, 2011
ASUS P4V8X-X Motherboard Logo
83 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
raid controller drivers
  • Computers & Internet
