20 Most Recent ASUS K8N4-E Deluxe Motherboard Questions & Answers
ASUS K8N4-E Deluxe wat is the maximum ram this
Error408,
Your motherboard Asus K8N4 Deluxe can accommodate up to 3GB of single channel DDR memory.
12/16/2009 12:51:29 AM • ASUS K8N4-E... • Answered on Dec 16, 2009
2answers
ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
12/1/2009 7:53:57 PM • ASUS K8N4-E... • Answered on Dec 01, 2009
NO DVI or VGA SIGNAL to MONITOR
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
10/2/2009 4:46:56 PM • ASUS K8N4-E... • Answered on Oct 02, 2009
Hi i just pieced together
holy shet ******** ...........................you i will kill you shet
12/28/2008 11:21:32 AM • ASUS K8N4-E... • Answered on Dec 28, 2008
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
12/12/2008 7:30:50 PM • ASUS K8N4-E... • Answered on Dec 12, 2008
Repair asus k8n4-e deluxe
null
9/7/2008 7:02:30 PM • ASUS K8N4-E... • Answered on Sep 07, 2008
Did you fixed your problem with the keyboard and de asus k8n4-e deluxe?
I do not know what to answer..
I do not know what is your problem.
9/3/2008 12:52:16 AM • ASUS K8N4-E... • Answered on Sep 03, 2008
Unable to use F6to load raid controllers
Did you actually attempt a bios Flash, that failed ?
Have you also made sure that the device is set to recognised by the system bios ?
Mike @ Compurepair.
Posted @ 23.35 PM ( G.M.T )
8/28/2008 7:12:31 AM • ASUS K8N4-E... • Answered on Aug 28, 2008
It's me in florida, USA
Buddy don,t forget I,m 5 Hours In Front Of You Time-zone Wise.
It,s Now 11.20PM UK Time, i guess you,ll be About 6.20PM.
If i,m still awake sure, i,ll give you my best advice that i can possibly give.
Regards Mike.
3/8/2008 12:09:06 AM • ASUS K8N4-E... • Answered on Mar 08, 2008
No Hard drive recognized when starting from disc.
I do not use "Mattozan", games or VR software (I only use my PC for work/code writing). But if the Mattozan software specifies that you should flash from "within" windows environment, and leaves no room or reason for you to assume otherwise, there may be a good reason for that. Modern flash BIOS can be updated "live" from within the OS. This allows other active OS processes to be utilized, which cannot be accessed from a boot floppy/CD made specifically for flashing BIOS.
However, that being said, my personal preference is to use the boot floppy/CD method for flashing BIOS, because the OS may be contaminated by a virus, that can permanently damage your PC if this is the case, when you update.
Thus, you have two choices; take a risk, and follow Mattozan advice. But I would strongly urge a VERY thorough virus scan, including RAM and MBR, before doing this.
The ONLY safe option is to flash your BIOS with an update supplied DIRECTLY from your BIOS or mfg/motherboard web site, which has some signature or encryption verification (to assure it is authentic, not supplied by some 13 year old Chinese or Russian hackers who hijacked the website), and then, to apply the update from the floppy/CD booter. This completely bypasses your OS, so if the OS is damaged, the BIOS will still be correctly updated.
Thereafter, the Mattozan software, if it is legitimate and well written with safety as a consideration, should recognize the update and proceed normally. One exception might be if the BIOS is newer than the Mattozan software version (in which case you may need a Mattozan update as well).
Perhaps you can post the exact wording of the message/READ-ME for the software, and I can better advise you if there are other considerations to weigh?
3/6/2008 4:36:00 AM • ASUS K8N4-E... • Answered on Mar 06, 2008
Connecting audio
I took the liberty of finding you your Manual:
http://dlsvr01.asus.com/pub/ASUS/mb/sock754/K8N4-E_DX/e2009_k8n4-e_deluxe.pdf
Also, to spare you the trouble of going through it, here's the only reference you need:
[img]http://img301.imageshack.us/img301/9752/audioasusrc7.jpg[/img]
As you can see - YES - you can remove those and connect your front panel.
Hope this helps. Rate me. Thanks.
2/17/2008 3:55:40 AM • ASUS K8N4-E... • Answered on Feb 17, 2008
2answers
Never seen this before
Dear Cucubau,
I think your prob is at the ps2 slot at your motherboard...i suggest u shoult try a usb keyboard.I think that should do the trick...Have a nice day :)
11/28/2007 2:45:48 PM • ASUS K8N4-E... • Answered on Nov 28, 2007
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
Need wiring connections for asus M4a785-m motherboard.
Visit M4A785-M - Support (asus.com) and download the required manual.
9/19/2023 12:31:26 PM • ASUS Computers &... • Answered on Sep 19, 2023
ASUS K8N4-E Deluxe Motherboard Logo
17 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus k8n4 e deluxe wat maximum ram
  • Computers & Internet
