20 Most Recent ASUS AC Adapter- Universal Notebook AC Power Adapter (NBACA407D2) Power Supply Questions & Answers
The pin in the laptop
I've seen this issue on an HP computer before. For some odd reason, some models decided to use "cost efficient" housing around the AC power unit on the inside of the laptop housing. If you know how to replace it yourself, I would recommend just acquiring the piece and replacing it on your own. There are some sellers on eBay who do provide quality products which are assembled with the highest standards.
7/28/2017 2:59:24 PM • ASUS AC Adapter-... • Answered on Jul 28, 2017
On electric power supplies, is the wire with the white stripe the positive or negative wire?
You have to check with a volt meter.
5/28/2014 8:04:29 AM • ASUS AC Adapter-... • Answered on May 28, 2014
2answers
Asus netbook ac power cord adapter stopped
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
3/19/2012 2:50:27 AM • ASUS AC Adapter-... • Answered on Mar 19, 2012
2answers
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
4/7/2011 3:35:12 AM • ASUS AC Adapter-... • Answered on Apr 07, 2011
Hi The Asus laptop power
theres a short in your laptop wire splice where short is then tape back.
2/5/2011 11:47:57 AM • ASUS AC Adapter-... • Answered on Feb 05, 2011
I need to order USB
PLease go to eBay and type in the Model# (not the serial) in their search box followed by "AC Adapter Charger" and you will have choices.
Regards,
The Selkie
9/28/2010 9:46:26 AM • ASUS AC Adapter-... • Answered on Sep 28, 2010
Asus ac adapter green light shows that it is
Super cost-effective Universal ASUS AC Adapter with 1 year warranty sell in famed and old battery power charger store.
9/6/2010 4:34:08 PM • ASUS AC Adapter-... • Answered on Sep 06, 2010
Does not charge
hi,
you can try to conect the laptop directly to the power outlet without using the battery just to verify if it the battery or the charger itself..If it still power up the laptop,that means that the adapter is still working,if not,well obviously,its the battery itself
thanks
7/6/2010 8:16:34 PM • ASUS AC Adapter-... • Answered on Jul 06, 2010
Green light is on on the adapter, but doesnt
1. the adapter may be ok but the unit battery that the adapter is charging may have a bad cell and not taking the charge or the power connector may need replacement .
Only a qualified tech can determine this by doing electrical checks with a meter and or diagnostic instrument.
Take your unit to a tech to do a diagnostic.
More than likely it is the battery.
1/29/2010 4:39:58 AM • ASUS AC Adapter-... • Answered on Jan 29, 2010
Only a few things come to mind:
1. The plug on the MB is defective
Solution: Have the plug on the motherboard replaced
2. The universal power adapter is defective
Solution: Buy an ASUS power adapter and test it out. If it doesn't work, return it. If it does, then get rid of the universal adapter.
Good luck
-Carlos:
1/7/2010 4:31:10 AM • ASUS AC Adapter-... • Answered on Jan 07, 2010
My asus laptop cant turn on
you need to replace the Power button...
7/7/2009 4:20:13 PM • ASUS AC Adapter-... • Answered on Jul 07, 2009
My ac adapter heats up & gets extremely warm.
As long as it doesnt burn your hand or start smoking ...don't worry about it. All laptop "bricks" get hot .... no cooling inside there ...
1/3/2009 6:38:15 PM • ASUS AC Adapter-... • Answered on Jan 03, 2009
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
Need wiring connections for asus M4a785-m motherboard.
Visit M4A785-M - Support (asus.com) and download the required manual.
9/19/2023 12:31:26 PM • ASUS Computers &... • Answered on Sep 19, 2023
Asus rog rg8 ii dont power up
6/23/2023 6:50:54 PM • ASUS Computers &... • Answered on Jun 23, 2023
Computers & Internet Logo
14 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus ac adapter green light shows
  • Computers & Internet
