20 Most Recent AO Smith Evcon Draft Inducer Furnace Blower 2702-3201a Ja1p092 U961 Questions & Answers
HEATER
ax fan may be going out
11/6/2013 9:39:27 PM • AO Smith Evcon... • Answered on Nov 06, 2013
Commroy
update your java
7/3/2014 12:28:23 AM • AO Smith... • Answered on Jul 03, 2014
I need to replace a 1hp cont pool pump motor and dont know which 2 get... please help
Probably, I assume everything is c-face and it has enough power.
6/18/2014 5:56:49 PM • AO Smith... • Answered on Jun 18, 2014
Water heater pilot turns on but burner won't light. 4 blink meaning high temp shutdown. What can I do?
We have a Model 2801052103 Franklin Electric submersible pump, 1/2HP 230 Volt. It starts and stops when using water frequently. System is 30+ years old, could the well be bad?
1/5/2014 9:57:06 PM • AO Smith... • Answered on Jan 05, 2014
My above ground pool pump (Hayward Pool Model
check flot
11/6/2013 9:33:43 PM • AO Smith... • Answered on Nov 06, 2013
2HP AO Smith on an
have a service person look at this motor
11/6/2013 9:33:08 PM • AO Smith... • Answered on Nov 06, 2013
Need tell end bearings for
call help desk
11/6/2013 9:25:42 PM • AO Smith... • Answered on Nov 06, 2013
I just replaced the seal, then I install back the
you may have change the motor rotation
11/6/2013 9:02:02 PM • AO Smith... • Answered on Nov 06, 2013
My water pump is locked and is making a hum noise.
IS IT AN ABOVEGROUND OR SUBMERSIBLE (INGROUND) PUMP. USUALLY THIS IS CAUSED BY A BAD CAPACITOR OR BURNT POINTS ON THE PRESSURE SWITCH. THE CAPACITOR IS EITHER IN A RELAY BOX AT THE WELL OR IN THE MOTOR CASING. HOPE THIS HELPS. JODY
1/16/2011 3:06:40 AM • AO Smith... • Answered on Jan 16, 2011
I have a spa 2 speed pump BN55 part 7 -186364 -02.
If the problem is the motor you could probably get the data needed off the motor's brand label and find an equivalent one on harborfreight.com or something.
12/17/2009 12:13:29 AM • AO Smith... • Answered on Dec 17, 2009
PREASURE NOT HIGH LIKE IT WAS 5 YEARS AGO
Plastic impellers and pump cases are great for circulation applications but tend to wear out in pressure and or dirty water applications. The space between the impeller and case gets larger as it wears until the pump just circulates water inside the case.
Pump selection is dependent on applications, with pressure, volume, suction, temperture and fluid to be pumped only a few of the considerations.
Check for restricted suction strainer and hose first, then look at discharge side for kinked hoses and other obstructions. Then open case and look for worn impeller and volutes, occasionally there will be something lodged in the impeller like string or plastic film. Replacing the impeller alone if badly worne may help but won't bring the pressure back to new pump specs, you will need to replace the volute or case too if they are combined.
I use cast iron pumps for pumping silt laden irrigation water and have to rebuild them every 5-6 years, My suction head is 3' and head pressure is 35 psi. frankly I expected better life from cast iron but have to take what I can get.
8/14/2009 5:07:59 PM • AO Smith... • Answered on Aug 14, 2009
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
2answers
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM • Plumbing • Answered on Oct 19, 2023
My Mirolin bath drain stopper had a spring, which went down the drain when I removed the stopper to clean. Now I'm not sure how the new spring I bought goes back on.
This seems like a system which is proprietary to them, so best to ask their Support staff https://mirolin.com/contact-us/ You could have retrieved the old spring with a flexible magnetic reach tool. https://www.google.ca/search?q=magnetic+pickup+tool https://www.google.com/search?q=Mirolin+bath+drain+stopper ..
10/10/2023 11:30:47 PM • Plumbing • Answered on Oct 10, 2023
AO Smith Evcon Draft Inducer Furnace Blower 2702-3201a Ja1p092 U961 Logo
1 questions posted
Top AO Smith Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Plumbing
  • AO Smith Plumbing
Most Popular Question
heater
  • Plumbing
