20 Most Recent
Honda Eb3500 Eg3500 Em3500 Ew140 Generator Recoil Starter Cover Questions & Answers
Sputters dies after 5 minutes
If it runs at all, then it is not the spark, so it must be fuel.
Flush the tank and put in new clean fuel. If it still does not run right, then you probably need to rebuild the carbureator.
How to remove tank on a honda eg5000cl generator
This is reasonably easy to do. Does the Generator run? Start the generator as it's running turn the fuel Petcock to the Off position. The generator should stall and stop running. This helps safely empty the fuel line and carburettor between the tank and the engine.
Disconnect the fuel line from the petcock tap and plug the ends to stop dirt getting in. On each corner of the tank itself there should be a bolt going through the ribbed edge and a rubber spacer. remove these 4 bolts and the tank should lift up and out. On some generators you might have to remove some trim panels to make it easier.
Refitting is the exact opposite of this.
Honda EX5500 power output
It sounds like you are experiencing an issue with your ex5500 generator where the voltage and frequency are not within the correct range when the generator is running. Here are a few steps you can try to troubleshoot the issue:
- Check the load: Make sure that the load you are running on the generator is within its capacity. If the load is too high, it can cause the generator to run at a lower frequency and higher voltage.
- Check the fuel level: Make sure the fuel tank is full and that the fuel is fresh. If the fuel is stale or contaminated, it can cause the generator to run poorly.
- Check the spark plug: The spark plug is responsible for igniting the fuel in the engine. If the spark plug is dirty or worn out, it can cause the generator to run poorly. Clean or replace the spark plug as needed.
- Check the air filter: The air filter is responsible for cleaning the air that is drawn into the engine. If the air filter is dirty or clogged, it can restrict the flow of air to the engine and cause it to run poorly. Clean or replace the air filter as needed.
If none of these steps help resolve the issue, it may be necessary to have the generator checked by a professional. They can diagnose and repair any underlying issues that may be causing the generator to run poorly.
Honda em5000sx generator runs too fast
it's possible that u may have a worn washer underneath the governor gear it's internal this washer wears due to lack of oil change 4800 is way too high for that engine to operate 38oo max parts are inexpensive although doing the job to repair it is another it's behind the front cover of engine you need washer slider and governor gear totl cost of parts under 30.00.
