Welcome to Fixya
Try to use this
driver. this works with several MAC PC's. Here's the procedure:
Step 1
Turn ON the Printer, Connect to Mac via the USB port/cable
Step 2
Go to Printer Setup Utility (located /Applications/Utilities/Printer Setup Utility) and click the "add printer" icon in the toolbar. This will display the "Printer Browser"
Step 3
Select the LBP3000 (USB) from the list. If it doesn't appear, disconnect USB cable and reconnect. Failing that, turn the Printer OFF/ON.
Step 4
The pop-up menu at the bottom, titled: "print using" should automatically select "CAPT Driver". Click the "add" button. There is nothing manual to select here. It either appears if software installation was successful. It it doesn't appear, re-install. Go back to Step 1.
Step 5
Verify that your new USB connected printer is working. Do a test print from the Printer Server that is physically connected to the printer.
Step 6
Enable Printer Sharing, System Prefs > Sharing > Tick/enable Printer Sharing.
Step 7 (on your Mac)
Install the same software on your client (non print server) Mac as in Step 1,
(the software forces a restart, so save your work first)
Step 8
Step 9
Select the LBP3000 (Shared Printer) from the list. If it doesn't appear, check that your Print Server Mac can still see/connect to the printer (refer Step 4)
Step 10
The pop-up menu at the bottom, titled: "print using" should automatically select "LBP3000". Click the "add" button. There is nothing manual to select here. It either appears if software installation was successful. It it doesn't appear, re-install. Go back to Step 9.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
