20 Most Recent Honda Snowblower Working Light Kit Hs624, Hs724 Questions & Answers
If you need more support, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 15, 2019
If you need more support, please visit www.dieselgeneratortech.com
Honda Electrical... | Answered on Oct 10, 2019
For your question, i have replied many people, why generator set can start but not generate electricity?
Here is some reasons for reference:
1.After the diesel generator is stopped, the residual magnetism is often lost, because the material used for the magnetic pole of the exciter is close to the soft steel, and the residual magnetism is small. After the shutdown, when there is no current in the excitation winding, the magnetic field will disappear.
2.The magnetic pole of the diesel generator loses its magnetic properties.
3.Damage of excitation circuit components or circuit breakage, short circuit or grounding phenomena.
4.The exciter brush is not in good contact with the commutator and pressure of brush holder is insufficient.
5.Excitation winding wiring error, opposite polarity.
6.Stator winding and rotor winding of generator set open circuit.
7.Poor contact between diesel generator brush and slip ring, or insufficient brush pressure.
8.Diesel generator lead wire wiring is loose or switch contact is poor.
9.The fuse box is fused.
10.The "auto-manual-de-excitation" switch on the control panel is in the de-excitation position (automatic generator set has "auto-manual-de-excitation" switch).
11.The voltmeter is damaged.
12.Rotary rectifier module is damaged.
Honda Electrical... | Answered on Oct 09, 2019
Most of the time it is either the Capacitor or AVR that has blown (depending on what is fitted on your generator.). Check out our videos on how to test them.
We hold a full range of Generator AVRs and Capacitors. https://www.generatorguru.com
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Honda Electrical... | Answered on Aug 19, 2019
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Honda Electrical... | Answered on Jul 27, 2019
you probably have either a bad capacitor or more likely a short stator winding due to previous overloading
Honda Electrical... | Answered on Jun 03, 2019
Verify that the double gang circuit breaker is good on both sides. Check for loose wire on breaker or receptacle.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Honda Electrical... | Answered on May 31, 2019
use your car battery and jump it. you cannot get too big a battery. big is better.
Honda Electrical... | Answered on Apr 10, 2019
If it's on a Ryobi Generator then it should be a real Honda Engine. It's possible that it's a knock off or was replaced with one. If you bought it new from a reputable source then it's real, if it's used or came from an offshore source for a really low price then it's a good possibility that it's a kkoxk off. In all honesty, from my experience they do a great job with the knock off engines & they're usually reliable and last a normal life span similar to a real name brand.
Either way, that mechanical Issue Remains, I'm assuming you're refering to the valve being stuck and basically keeping the engine locked up and not allowing it to the over when attempting to start it. Sounds likely. Did you take the spark plug out and turn it over to see if it'll turn over at all to ensure it's not just totally locked up? My suggestion would be to Remove the valve cover and spark plug so that you can see the valvetrain in action when(if so) it is turning over and observe it to see if your valve theory is correct!
Thanks and good luck my friend, see the infinity below please, have a great day!
Honda Electrical... | Answered on Mar 18, 2019
The reduced atmospheric pressure at high altitude means the standard carburettor settings will not allow sufficient fuel to flow for efficient running.
The dealer or manufacturer should be able to provide details of alternative settings - the jet sizes are usually increased a few points for every 5000 ft above sea level.
The cooler temperatures experienced at high altitude would probably change the engine oil specification to a lighter or thinner grade.
Honda Electrical... | Answered on Feb 26, 2019
The Honda 5.0 gc160 owners manual calls for an NGK BPR6ES for proper heat range. Should be available at any Lawnmower shop or online at ebay
Honda Electrical... | Answered on Feb 21, 2019
I would suspect that the inverter is fine and would look towards carburetion. The inverter, in addition to supplying the correct voltage and current, monitors the current being drawn by your connected load. It controls that stepper motor on the top of the carburetor and increases the throttle to increase the engine power to support the load. (Mechanical power in = electrical power out.)
Start the generator and then add a small load to the outlet, 100 watt light bulb or something. I use a space heater that I can turn on just the fan. See if it still stays running. Then increase the load (with my heater I go from fan only to the first level heat 1000w) and watch the top of the carburetor to see if the inverter increases the throttle to compensate for the increased load. By the sounds of what you are describing, it will go to full throttle and the engine will die because of a restriction on the available fuel. If that is the case, take the carb off and clean it. Or if you are not the carburetor rebuilding type, buy a new one.. they are only about $80. Not a bad fix for a $2000 generator :)
Honda Electrical... | Answered on Feb 14, 2019
Likely a valve stuck open. Pop the head off and verify. If so, try to free it by spraying a a light oil around the valve stem and possibly rotating the valve to free it. If you damaged the head gasket removing the head, it will have to be replaced. Be careful to torque the headbolts symmetrically so as not to crack the head. There will be a troque spec but I do not know what that is.
Honda Electrical... | Answered on Feb 01, 2019
sounds like a dirty carb inside. try running some fuel system cleaner or seafoam through it before tearing it apart
Honda Electrical... | Answered on Jan 21, 2019
Honda Snowblower Working Light Kit Hs624, Hs724 Logo
3 questions posted
Top Honda Electrical Supplies Experts
John Trevino
Norman Al-Anbar
Sheldon Dedek
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electrical Supplies
Most Popular Question
ex1000 honda generator getting no gas
  • Electrical Supplies
