20 Most Recent Canon BJC S600 InkJet Printer Questions & Answers
My Canon S600 has no
I use to have a Canon with the same issue as yours. Do you refill your own ink tanks? If so, that is the problem because they leak inherently after awhile. If they leak then your print head is probably clogged. Was this a gradual problem or did it occur all at once? That will make a difference in troubleshooting your problem. Another issue with Canon printers is that you have to use them often of the print heads will clog up after a period of time. Take a look at this video as well. It may help you!
1/9/2018 2:38:37 PM • Canon BJC S600... • Answered on Jan 09, 2018
Model is Canon S600. I
it might the catrige ink coagulated better remove it and dip it in mild hot water for some times and replace it wiping the water it might solve your problem.
5/15/2011 2:34:28 AM • Canon BJC S600... • Answered on May 15, 2011
Canon S600 printer colours are printing fine.
You may get your answer in the website link below. Click on the link.
If may be time you need to replace the Printheads.
Canon Link
Regards,
Ron
2/11/2011 9:18:26 PM • Canon BJC S600... • Answered on Feb 11, 2011
The yellow light quit flashing
Hi Rowleyruth,
Please follow the below steps:
1. Turn off your printer and disconnect all the possible removable accessories like catridges, tray, etc and switch on your printer.
2. Remove all the drivers and software regarding your printer from your computer and reinstall them back using the driver cd which came along with your device.
3. Connect back all the removed parts to your printer and connect it to your computer and try again.
Please let me know if in case the problem is not solved and i ll suggest you with some other trouble shooting steps.
I hope this might help you
thanks
7/6/2010 5:21:43 PM • Canon BJC S600... • Answered on Jul 06, 2010
The message says that my
Does your printer use a USB connection? Did you install the printer's driver before connecting the printer to your computer? Was your printer working before?
7/5/2010 11:38:21 AM • Canon BJC S600... • Answered on Jul 05, 2010
2answers
Yellow light flashes 7 times
Hello.
Your printer may just need to be reset:
Power off the printer, disconnect the power cable from its source (power strip or outlet). Leave the printer unpowered overnight.
That should resolve your issue.
Hope this helps.
7/4/2010 4:45:57 PM • Canon BJC S600... • Answered on Jul 04, 2010
Set of 4 alternating orange and green flashes
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
3/31/2010 2:47:22 PM • Canon BJC S600... • Answered on Mar 31, 2010
2answers
Is the Canon S600 printer compatibl with Windows
Have you tried to connect the printer?
If so, did Windows 7 recognize it, and load the correct device-drivers?
If not, access the manufacturer's web-site:
http://www.usa.canon.com/opd/controller?act=OPDSupportWindows7Act
Select "Printers".
Select "S" series.
Is your printer listed among those that are supported by Windows 7?
11/19/2009 11:07:52 PM • Canon BJC S600... • Answered on Nov 19, 2009
My computer is unable to open twain driver
You need to reinstall the twain driver at this time, or use a different application program inorder to scan. that should fix the issue.
Let me know
Thanks
K
4/28/2009 4:32:31 PM • Canon BJC S600... • Answered on Apr 28, 2009
you may need to reinstall the twain driver at this time, or use a different application program inorder to scan
appreciate your kind comment
4/21/2009 3:36:31 PM • Canon BJC S600... • Answered on Apr 21, 2009
Error 5100 for canon s600 bubblejet printer
try these points ----
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
3/9/2009 5:32:40 PM • Canon BJC S600... • Answered on Mar 09, 2009
Canon S600 bubblejet priner won't print color
In all likelihood, the nozzles in the printhead are blocked. The printhead is the carrier that holds the tanks. Remove the printhead and remove the tanks from the printhead. Flush the printhead THOROUGHLY with hot running water. You can also **** on the color discharge area (square and the black discharge area (rectangular) on the bottom to draw warm watr through the nozzles to further clean them. Dry the prinhead thoroughly, reinsert your tanks and reinsert the printhead in the printer. I then do a "nozzle check" to refill the passages in the printhead and get things flowing agan.
1/22/2009 2:28:56 PM • Canon BJC S600... • Answered on Jan 22, 2009
Paper will start through printer
i think its asking if you are using right kind of paper specified to be used with your printer there are alot of different types of thickness in paper out there make sure your using the right one
6/2/2008 11:02:08 AM • Canon BJC S600... • Answered on Jun 02, 2008
Canon BJC S600 InkJet Printer Logo
Popular Tags
19 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
BJC Canon
  • BJC Canon
Most Popular Question
set 4 alternating orange green flashes
  • Office Equipment & Supplies
