20 Most Recent
Canon imageRUNNER 1600 Laser Printer Questions & Answers
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to
"#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER
RESET." Power the unit off/on.
3/8/2018 8:57:35 PM •
Canon...
Answered
on Mar 08, 2018
I have a cannon ir1610,
I have a big problem on the Canon ir 1610 the drum handle on left side was broken and the error come at screen E100 what should I do now? I check the handle was not broken completly but was only the top part
Please advice me with some big help !!!! Thank you all
4/16/2014 8:24:39 PM •
Canon...
Answered
on Apr 16, 2014
Ir 1600
instal the driver
2/5/2014 9:51:23 PM •
Canon...
Answered
on Feb 05, 2014
Check printer cover
If you have an owners manual, I would check there first to find how to solve the problem. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. This is just a shot in the dark and and I would try the owner's manual first, but after all other options have failed, and if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings which might solve the problem. You will loose any settings and any work in progress. You can also Google the name of the printer and the problem to see if any solutions are given in the many tech forums online. Good luck.
11/11/2013 8:54:27 PM •
Canon...
Answered
on Nov 11, 2013
Same online, job, alarm (led)
Did you try to print something from the computer?
If yes, then check the paper size under printer properties, and custom paper size (if you are printing on A4 it needs to be set on A4).
Then turn off and on your copier.
If that isnt the case pls. describe the problem from begining with details.
4/26/2013 9:29:49 PM •
Canon...
Answered
on Apr 26, 2013
Check printer cover mesage
Open that cover and close it using some force is quick and the costumer can do it also.
The perfect solution for a technician:
The machine detects the opening of the lower door on the left side
(under the manual tray) as a cover open. There is one sensor for paper
jam and cover open. If the lower right door is open, the
photointerruptor is free. If you close the right lower inner door, it is
blocked, and when it is closed, and there is a paper in this section
the sensor is free. Sometimes the edge of lower inner door doesn't makes
the sensor moving, insted of crushes up. Then a little amount of grease
can help you.
See attachment:
3/1/2013 1:03:33 AM •
Canon...
Answered
on Mar 01, 2013
System Error E000
press *28*, select copier, err,clear,ok. switch off the copier and switch on after 60secs. hope it works.
11/28/2012 5:26:43 PM •
Canon...
Answered
on Nov 28, 2012
Canon np 3030 copy problem
print something from the Menu or report (do not make a copy) if it comes w/ the problem. Could be dirty laser glass or toner empty. if it comes normal, It's a dirty dOCUMENT SCANNER.
10/20/2012 3:28:42 AM •
Canon...
Answered
on Oct 20, 2012
System error E000.The buttons are
this is error related to fixing temperature. If there is no fault in fixing section ( lamp, thermistor, ... ) it can be cleared by service mode.
Press Additional function key ( * ) and # on keybord, by the arrow + go to the #12 CLEAR, press OK and choose ERR and OK.
If the clear can't help You, that means that you need to remove fixing unit, find the faulty component and replace it. It's probably faulty heater lamp.
Hope that helps!
7/25/2011 9:50:50 AM •
Canon...
Answered
on Jul 25, 2011
How to reset error code e 003
Fuser low temperature after wait period or warm up in standby. Faulty thermister, lamp or PCB. Check fuser for jammed paper.Reset required, if you success good otherwise contact dealer.for resetting.
Press Additional Functions keyPress #Press > to #7 Printer FunctionPress SetPress > to #4 Printer ResetPress SetPress
Hope this helps. Please rate my response.Thanks.Have a good day.
9/23/2010 11:28:16 AM •
Canon...
Answered
on Sep 23, 2010
