20 Most Recent
Canon imageCLASS D760 All-In-One Laser Printer Questions & Answers
Canon D760 print problem - print image
Duplicated images on pages is either the drum, or fusing/setting unit. Since this is an all in one unit, I am assuming the ink/toner cartridge includes the drum. I suggest replacing the fusing/fixing unit. (the hot part of the printer"
Paper comes out white. No text. Reports will
The document scanner has light bar which Canon calls the "Contact Image Scanner" FH7-7565-000.
It is probably bad.
This unit is under the glass, so I'd recommend to get a service company to do this.
Whit
800-367-4836
www.iteminconline.com
Where is the platen located
The platen is the part that covers the large original glass. That is why this glass is sometimes called the "platen glass". More commonly the glass is called the original glass because that is where you lay the original to be copied if you are not using the feeder.
Thank You for using Fixya.
Paper jam is now clear ,still shows error light
If you reset the copier by open and close the top scanner, by moving it left and then right, and you still have a paper jam error on this model there are only 2 options one that there still a piece of paper holding the switch, 2nd option is that the switch is broken or out of place. If you remove the paper from the fuser, the left side of the machine, where it exit, your only option is to take the fuser unit out, and check the switch, recommended for technician only!!!
If you found the paper at the right side of the copier, take out the cartridge, lift up the metal plate on the bottom, swing it up and look for the paper.
Good luck.
