20 Most Recent
Canon imageRUNNER 1310 Printer Questions & Answers
Platen cover
Check The Platen Flap Sensor Or Dc Boardand rock bro.....
11/14/2013 3:35:44 AM •
Canon...
Answered
on Nov 14, 2013
Paper jam at output on the Imagerunner 1310
I have a solution. Take a baseball bat and knock the crud out of that ******! That will fix the problem of not having a door! Thus it will make a verrrrrry easy opening to get the paper out! :-D
6/19/2012 10:54:22 PM •
Canon...
Answered
on Jun 19, 2012
Check Toner/Drum CRG
I Replaced Both
Sounds like you need to reset your counters.
Check these areas on your printer to see if you can locate them.
To select events that will raise alarms:
1. In the navigation pane, expand the Canon Devices node and the Configuration
node, and click Alarm Management.
2. Select the check box for each type of information you want alarms generated for.
3. Click Apply.
Specifying Rates and Timeouts
To set rate and timeout values:
node, and click Rates and Timeouts.
2. In the Discovery Refresh Rate list, click how often the client should refresh the
navigation pane's list of discovered devices.
3. In the Alarm Poll Rate list, click how often the client should poll for alarms.
4/1/2011 1:29:58 AM •
Canon...
Answered
on Apr 01, 2011
Driver window 7
Below is a link to the drivers. I would try the vista drivers first. If they do not work then try win xp
1310 DRIVERS
Hope this helps!
Zeppelinx12
3/9/2011 1:13:49 AM •
Canon...
Answered
on Mar 09, 2011
