20 Most Recent Canon imageCLASS MF5750 All-In-One Laser Printer Questions & Answers
Mf5750 adjusting waiting to scan
Hello,We are an authorized Canon Service Center and I can tell you 90% of the time the solution is simple. The machine needs to "acclimate" itself.Just unplug it.....wait a second or two....plug it back in. The next part is the hardest - you have to wait. DO NOT touch any buttons or mess with the machine during this waiting period..and I mean nothing. Sometimes the wait can be 15 minutes. But after that all is good to go. The Canon MF3110 series is very similar and we have set-up around 100 of these. ALL of them were like this. No big deal. Being that were are an authorized service center for this machine and you might need a part or something, you can find us easily by go to: http://bopcanon.com/IMAGECLASSMF5750Series.aspxThanks :>)
10/16/2019 8:50:20 AM • Canon imageCLASS... • Answered on Oct 16, 2019
I have Canon ImageClass MF5750 and been having problem with paper size issue.it usually stop printing or photocopying and ask me to check paper setting even though the setting is looks okay(paper size
Make sure that the document you print is set to A4 or Letter, dependent upon the printer setup. If you try to print to the wrong size of paper, the printer will stop.
2/11/2015 7:11:19 PM • Canon imageCLASS... • Answered on Feb 11, 2015
Can a canon mf5550 work with mac os 10.5?
from the Canon website http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550#DriversAndSoftware Drivers & Software 1. Select a file from the "Recommended For You" section or click on "Show All" to see all files. 2. Click on the file you would like to download. 3. After agreeing to the terms of the Disclaimer by checking the box, click on the Download button. Operating System: Show All arrow_down.gif Drivers There is no driver for the OS Version you selected. The driver may be included in your OS or you may not need a driver.
8/28/2014 6:13:46 AM • Canon imageCLASS... • Answered on Aug 28, 2014
How can I enter the system menu to reset my Canon
1) Enter into service mode: Menu -> 2 -> 8 -> Menu 2) To clear all the settings: Copier -> Function -> Clear -> All
7/10/2014 6:08:39 PM • Canon imageCLASS... • Answered on Jul 10, 2014
2answers
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
6/24/2014 5:11:57 AM • Canon imageCLASS... • Answered on Jun 24, 2014
Is there a transparency adapter for canon imageclass MF5750 series?
Hey There, Boy, this model is getting pretty old. Very basic as far as options out there. I strongly suggest not running transparencies in this model. We have seen so many of these come in with them stuck and melted in the fuser section.
4/30/2014 1:10:37 AM • Canon imageCLASS... • Answered on Apr 30, 2014
Cleaning roller
lift the feeder open (as if you were going to copy off the glass)now look at the skinny glass to the left of the big glass you will see dirt there get some windex or alcohol on a rag or something and wipe it off if you do not have alcohol use cologne or something and get all the dirt off then try making a copy using the feeder problem solved guaranteed:)
10/24/2013 8:23:37 PM • Canon imageCLASS... • Answered on Oct 24, 2013
0answers
2answers
Check document, however there is no document to
check document on your canon ImageClass means that you need to check the ADF (Automatic Document Feeder) the feeder on the top of your printer. open it check for any paper inside .. if nothing turn off the printer and unplug from the wall.. wait for 30 seconds plug back in the power plug and turn back on.. let me know I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
9/5/2013 10:44:29 PM • Canon imageCLASS... • Answered on Sep 05, 2013
Driver windows xp
How did U determine its Driver problem?Try this: 1. makesur printer software from cd installed properly and2. this printer is a default printer3. check cable connections fro P to cpu.4. check if settings ok.5 print test page.goodluck
8/15/2013 3:00:31 AM • Canon imageCLASS... • Answered on Aug 15, 2013
My printer can not printer and scaner
Try reinstalling the printer driver. You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
5/8/2013 12:01:53 PM • Canon imageCLASS... • Answered on May 08, 2013
Canon mf 5750
i fix the problem changing the heather......
2/15/2013 3:58:15 PM • Canon imageCLASS... • Answered on Feb 15, 2013
How to i clean the drum - there is a mark every few inches when i print
If the mark is persistent on each page and repetitive with very precise spacing, you need to determine which roller it's coming from. It could be coming from the transfer roller, before the fuser, the fuser itself, or the fuser pressure roller. Measure the spacing distance of the mark(s), then measure the diameter of the 3 above mnetioned rollers, multiply by pi (3.14159265) and compare the results to determine exactly which roller is causing the issue, then replace that particular roller. Hopefully it's not the fuser as you'd be better-off replacing the fuser film (main fuser roller lining). The fuser and pressure roller are a pain to source, and run abou $65+ for the pressure roller, and about $90+ for the fuser, not to mention this 2 last rollers will take about 1-1.5 hours to replace. They are not hard to replace using common tools. Don't forget to locate the printer service manual over the internet first.
2/4/2013 4:59:41 PM • Canon imageCLASS... • Answered on Feb 04, 2013
How to connect networking printer canon
Check your router status page for connected devices and then use an internet browser to connect to the assigned IP for your printer. From there you can configure the printer for your network. If you have issues, then perform a factory reset of the printer and then repeat the steps above, this will clear-out any previous network configuration that was setup on it, making it much easier to configure.
2/4/2013 4:52:45 PM • Canon imageCLASS... • Answered on Feb 04, 2013
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
159 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
mf5750 adjusting waiting scan
  • Office Equipment & Supplies
