20 Most Recent Canon 5200F Flatbed Scanner Questions & Answers
0answers
Faint scan
Be the first to answer 1/30/2014 3:16:27 AM • Canon 5200F... • Posted on Jan 30, 2014Be the first to answer
0answers
Canon 5200f
Be the first to answer 9/27/2013 9:37:01 AM • Canon 5200F... • Posted on Sep 27, 2013Be the first to answer
CS not appearing
Hi.
Do you mean the Canon Scan is not appearing or being recognized by your computer? If that is the case, make sure that the driver is properly installed in your computer. Also make sure that the USB port and cables are working properly.
Cheers!
12/7/2010 1:41:37 PM • Canon 5200F... • Answered on Dec 07, 2010
Documents are not sharp almost like double vision
Since it takes several scans to get a clean scan, this would indicate the bulb as the bulb warms up over time and gets brighter. If it were a problem with the optics, then the result would be the same on each scan. There are several parts houses on the internet where you can purchase scanner parts. Type in Canon 5200F scanner bulb replacement into your search engine and you'll find several. Compare prices and shipping for your part to select the best choice (also check their return policy in case you receive the wrong part).
3/10/2010 7:49:29 PM • Canon 5200F... • Answered on Mar 10, 2010
Set-up CD-ROM does not seem to have accessible
Yes, try the Canon website. http://software.canon-europe.com/products/0010070.asp select your OS and download the driver/software package.
10/14/2009 4:43:17 AM • Canon 5200F... • Answered on Oct 14, 2009
Negative or positive option is not available on
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
7/25/2009 1:11:54 PM • Canon 5200F... • Answered on Jul 25, 2009
2answers
Ir2116j canon copier to download driver free
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
4/7/2024 3:16:49 AM • Canon Office... • Answered on Apr 07, 2024
Canon ipf605 printer won't let me in service mode, I can get the S in the top right but no initializing
images-undefined-undefined-0_15.jpg If your Canon iPF605 printer won't enter service mode and gets stuck at the "S" symbol without initializing, it may indicate a firmware or hardware issue. Consider updating the firmware or contacting Canon support for further assistance. images (1)-undefined-undefined-1.jpg
4/6/2024 3:29:06 PM • Canon Office... • Answered on Apr 06, 2024
Canon Calculator. How come I cannot use the calculator due to error on it?
They make a few, mains, battery, solar, solar with battery. https://www.google.com/search?q=Canon+Calculator Disconnect power for 30 minutes to reset it. Generic Canon Errors https://www.google.com/search?q=Canon+Calculator+error+message ..
4/3/2024 6:07:02 PM • Canon Office... • Answered on Apr 03, 2024
Scanner canon dr6030 cants pull the paper
Troubleshoot this issue step by step: Check the Feed Selection Lever: Ensure that the Feed Selection Lever (located on the lower left side of the front of the scanner) is in the correct position (up) for separation. Straighten the edges of the stack of documents to be scanned. Set the document guides so they are wider than the document to be scanned. Place the documents face up into the feed tray, ensuring they touch the document stoppers. Clear Any Jammed Paper: Be careful when removing jammed paper to avoid cuts. Remove any documents that have been left in the eject tray. Close the document eject tray. If the document ejection is stopped partway, perform this operation with the document eject tray extension open. Hold the upper unit as shown in the diagram and open it to the point where you can remove the jammed document. The pickup roller is located in the middle of the upper unit. Do not hold the protrusion on the upper unit when opening it, as it may deform the pickup roller or cause a feeding error. Close the feeder cover. If the jam occurred in the feed section, pull the document out carefully without applying too much force. Be sure to remove any torn parts remaining in the scanner. Close the upper unit slowly, ensuring it clicks into place. Do not force it to close, as this may damage the scanner. After removing the jammed paper, check if the last page was scanned, and then continue scanning. Rapid Recover System: If a paper jam occurs when the "Rapid Recover System" is enabled in the ISIS/TWAIN driver settings, the image of the document is not saved, and scanning stops. You can continue scanning from the document that caused the paper jam after fixing the issue. Additional Considerations: Make sure the pickup rollers retract when the machine is powered on. Check that the stopper plates are in the down position. Verify that the upper unit is completely closed after clearing the jam. Remember to handle the scanner components carefully to avoid damage. If the issue persists, consider seeking professional assistance or contacting Canon support for further guidance
3/31/2024 10:04:39 PM • Canon Office... • Answered on Mar 31, 2024
How do I clean the printhead on a Canon P23-DH V printing calculator?
I would use a soft toothbrush and a little Isopropyl Alcohol and then a lint free cloth and then give another gentle brush. There are some other ideas here. Take no notice of the answer by 'Marvin' on Fixya about dropping the head in boiling water, I think he thinks he is dealing with a colour inkjet printer. https://www.google.com/search?q=canon+p23-dh+v+printing+calculator+clean+print+head ..
3/28/2024 12:09:00 AM • Canon Office... • Answered on Mar 28, 2024
Canon imageRUNNER IR 3300 Monochrome Copier. The machine print fade blur paper means not correct line or spread out line color. Please help.
Contact Canon for dealer servicing. Optics or developer.
imageRUNNER 3300 - Support - Download drivers ...
Canon Middle East https://en.canon-me.com > imagerunner > series > ir3300 Scan from Canon multi-function devices to a mobile device, upload scans to cloud storage services, attach to and send emails, and print. Other Products ... ..
3/20/2024 5:44:21 AM • Canon Office... • Answered on Mar 20, 2024
2answers
I have a problem with my canon printer g3411. It has an error P03 but no paper jam. How do I solve my problem
Error P03 on a Canon printer typically indicates a paper jam, even if you cannot physically see any jammed paper. Here are a few steps you can try to resolve the issue:
  1. Turn off the printer and unplug it from the power source.
  2. Carefully check the paper tray and inside the printer for any jammed paper or debris.
  3. Remove any jammed paper or debris you find.
  4. Plug the printer back in and turn it on.
  5. Attempt to print again.
If you don't see any paper jammed in the printer, there are a few other things you can try to resolve the error P03:
  1. Try resetting the printer. To do this, turn off the printer, unplug it from the power source, and wait for a few minutes before plugging it back in and turning it on.
  2. Check the ink cartridges and make sure they are properly seated and have enough ink.
  3. Clean the printer's rollers. Rollers are the small rubber wheels inside the printer that move the paper through the printer. Over time, dust, debris, or ink can build up on the rollers and cause paper jams. Cleaning the rollers can help resolve the issue.
  4. Try to update the firmware of the printer. Sometimes, a firmware update can resolve the issue.
  5. Check the printer's settings, ensure that the size of paper loaded match the size of paper set in the settings.
If the problem persists after trying these steps, you may want to contact Canon support for further assistance.
3/19/2024 2:50:12 PM • Canon Office... • Answered on Mar 19, 2024
Canon imageRUNNER 2202. I keep getting out of toner message. I have changed the toner couple of times and even service the toner unit but it still gives me the message. Can anyone please help me out?
There are some videos that may help but most just say 'replace the toner cartridge'. It is always better to use genuine Canon cartridges for quality and fill level. https://www.google.com/search?q=canon+ir+2202+out+of+toner+message ..
3/14/2024 6:29:56 PM • Canon Office... • Answered on Mar 14, 2024
How to slove error e732-001 of canon ir 3225
The E732-001 error on a Canon iR 3225 indicates an issue with the fixing assembly temperature. Here are some steps to troubleshoot and resolve this error: Reset the Condition: Enter service mode by pressing the following sequence on the control panel: COPIER > FUNCTION > CLEAR > ERR. This will reset the error condition. If the message disappears, your printer is ready to use. If this doesn't work, there may be a hardware problem as addressed below. Replace the Main Thermistor: The main thermistor is responsible for temperature sensing. If it's faulty, it can trigger the E732-001 error. Consider replacing the main thermistor to resolve the issue. Check the DC Controller PCB: If the problem persists, inspect the DC controller PCB for any defects or malfunctions. Replacing the DC controller PCB may be necessary. Remember to turn off the printer before performing any maintenance tasks. If the error persists or if you need further assistance, I recommend contacting your local authorized Canon dealer or the Canon Customer Support Center for professional service
3/14/2024 11:28:40 AM • Canon Office... • Answered on Mar 14, 2024
Canon imageRUNNER 2016. Paper jam open left cover was it power supply.
Question edited to add model name. Paper jam https://www.google.com/search?q=Canon+imageRUNNER+2016+Paper+jam Open left Cover
Thread: Paper jam, open Left Cover - Canon
Copytechnet https://www.copytechnet.com > ... > Canon Sep 24, 2013 - I am working on a Canon IR2016J. After I serviced the machine the above indication appears: "Paper Jam Open Left Cover". I have checked the ... iR2016 showing paper jam constatly Jan 23, 2009 Error Code Front cover open error Nov 29, 2022 canon ir2020 false jam Apr 16, 2012 canon ir-2016 showing download standby Sep 28, 2010 More results from www.copytechnet.com Power Supply https://www.google.com/search?q=canon+imagerunner+2016+power+supply ..
3/13/2024 5:55:18 PM • Canon Office... • Answered on Mar 13, 2024
Canon 5200F Flatbed Scanner Logo
14 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
set up cd rom not seem accessible
  • Office Equipment & Supplies
