20 Most Recent
Canon CanoScan FB630U Flatbed Scanner Questions & Answers
I cant find a driver for my canoscanFB630U for Vista any Ideas?
Canoscan FB630U - No need to buy 'VueScan' - that does work but $70 is a long way towards a new scanner.
I've had no problems using the XP canon driver (v. 5.3.2.0) under vista (just download, decompress then 'Update driver' in the device manager and point it to the decompressed files).
This is a TWAIN driver not the newer WIA type driver which means that the scanner will not appear in Windows Fax and Scan or in the the Scanners and Cameras group of control panel. Photoshop / Paintshop pro etc are perfectly happy to use TWAIN scanners, however!
Hope that helps someone!
Trying to install CanoScan FB 360u on Mac OS X
1)Here is the Link to get the toolbox
CLICK HERE
2)As for the plugin
(Applications>CanoScan Toolbox 4.1>Plug-Ins) put one here after you have the toolbox installed
3)You must have photoshop of any version to do the next step
4)If you do Put it here (Where ever your photoshop folder is> Plugin)
And go mac's
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
