20 Most Recent
Canon CanoScan FB620U Flatbed Scanner Questions & Answers
Scanner won't move?
These have quite a flimsy rubber drive belt which can stick and go hard. If you can get to it you might be able to soften it up with a soak over night in olive oil. Finding a replacement might be difficult..
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
How can you scan text into Microsoft Word
When you scan a document, Choose the File type/format as RTF or Microsoft word if you find in the list.
After you have scanned the document as RTF, open microsoft word and Open the document you have saved as RTF.
It will be in editable format.
Let me know if you need any more help or find difficulty in scanning as Word file
I can't find a driver for a CanoScan FB621u that
Try this site.
http://www.pcdriversupdates.com/drivers/updatedrivers.php?t=Canon%2064%20Bit%20Driver&OVRAW=canon%20vista%20drivers%2064%20bit&OVKEY=canon%2064%20bit%20driver&OVMTC=advanced&OVADID=31009232021&OVKWID=165785657021
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
Scan drivers not installed
Did you receive a driver with your printer? If not you need to have one in order to install the software for the printer, in order for it to work properly.
