20 Most Recent
Canon CanoScan N676U Flatbed Scanner Questions & Answers
Can i get this scanner working with Windows 7?
as per Windows 7 Compatibility Center,
Canon CanoScan N676U Flatbed Scanner is not compatible with Windows 7.
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Canon%20CanoScan%20N676U%20Scanner&v=Canon&uid=&pf=1&pi=0&c=Printers%20%26%20Scanners&sc=Scanners&os=32-bit
I have recently re-instaled the
Have you also installed the software. You may have to use the scanner through windows, and not with the buttons on the scanner.
You may have just installed the twain drivers and not the software to be able to use buttons and advanced settings
Hi I have downloaded drivers for canoscan N676U
hi this may be a .inf file install, what you have to do is,go to control panel then add new hardware, then click next at next window,it will then search for hardware, then it will ask is hardware already connected, click yes ( make sure scanner is plugged in) then scroll all the way down to bottom of list to add new hardware,then click at next window install hardware that i manually select from a list,then select all devices,then click the have disk, it will then ask you to direct it to where you have downloaded the driver files to, then it will give you a choice , pick your one then install...done, hope this helps please vote thanks
I can't get my Canoscan n676u to work on my laptop
You can download the driver of CanonScan N676U for Windows Vista operating system and install it.
Please click here which you can download the driver. In the web page, under the headline “Drivers/Software Selection” select your OS (Operating System) as “Windows Vista”. Then, find the “Drivers” headline below and click on the file name “lide20lide30n670un676un1240uvst7031a_xpen.exe” to download. After downloading please install the drive running the downloaded exe file.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
How to download driver for canoscan N676U
Hi
Her is the link to download driver for canoscan N676U
For that Just go to the following link
And click download
select the download location
(This driver is For all Versions OF windows)
or,
Hope this will help you.
I get the message....
you need to install the driver and software for your device or you can scan images manually with photoshop
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
Scan drivers not installed
Did you receive a driver with your printer? If not you need to have one in order to install the software for the printer, in order for it to work properly.
