20 Most Recent
Casio Cassiopeia BE-300 Pocket PC Questions & Answers
Be-300
The password is an easy thing to get rid of. The problem is, a full factory restore is required. First do a hard reset and then restore the BE300 to factory defaults. The password will be reset.
Hard Reset: Press and hold the Power Button. At the same time, press the rest button on the left side of the device with the stylus (pen). You will see a blue scroll saying Initializing. Press and hold the OK button. Once the Initializing is done, the BE300 will go into the Safe Mode screen. Press OK and follow the instructions to the Restore Screen. From here, you can perform a Factory Restore but you need the original CD or a download of the Factory Restore BIN file.
For full BE-300 support, go to www.be300.org It's dedicated to the BE300 and everything you will need is there.
Help!!!
The BE300 uses PC Connect and will not work with Activesync. All the original software and upgrades are available at www.be300.org
Casaio be-300 pda
A Factory Restore will fix the password but you need to do a hard reset to get to the restore screen. Press and hold the power button. At the same time, press the reset button on the left side of the device with the stylus (pen). You will see a blue sroll saying Initializing. Press and hold the OK button. Once the scroll is finished, you will get the Safe Mode Screen. From there, press the OK button and follow the instruction until you get to the Restore Screen. From there, you can do a factory restore if you have the original CD or have the factory restore BIN file. Everything is available at www.be300.org
By the way, there are also newer operating environments available for the BE300. They will turn it into an almost fully functional Pocket PC will fully functional Today Screen.
Loses charge
The battery os more than likely dead. You can get factory batteries off Ebay or there are other replacement ones available. Go to www.be300.org You should find information on alternative batteries there.
Be-300 picture and music won't load
Be-300 is not the standard Win CE 3.0 It requires PCConnect software for communication.
Download it from the following link.
http://casio.monacocorp.co.nz/cassiopeia/
BE-300-How do I open it to remove the touch screen?
As I remember it has some plastic bulges that fit into some indentations. Some gentle prying toward the bottom should show you some success.
To get the things that hold it together apart you need to press in on one part and lift up on the other, but don't remember which.
If you don't get it email me and I will go dig my old one out of the junk box and see which is which.
It, by the way has a good screen/touchscreen I think, the light circuit got busted on it and I can't get parts.
BE 300 on xp home ed.
http://www.abfnet.com has a bunch of be'ers that can help you - you can also search the forum for ton's of answers.
One thing, if you have Microsoft Activesync on your system pc connect won't work unless you shut off the activesyncs access to usb ports. Just a thought.
Synching Groupwise with a Cassiopeia BE300
Check out Intellisync 5.01. It works for us, but it definitely is not as simple as with a Palm.
There are a few quirks, but it does work. My biggest complaint was that you have to manually copy their "Windows CE Autorun Manager" to your startup folder or the Groupwise info. will not automatically be sync'd everytime you sync with ActiveSync.
In their defense though, I think most of the issues are because of ActiveSync.
Be-300, Jk-710dc
I don't have the camera, but I would expect it will store those images in My Documents either in the Nand Dick area or (preferably) on the CF card. You would transfer them either through Copy and Paste with an Active Sync connection, or a PCConnect folder sync, or also with PCConnect using copy and paste within beXplore. Another method would be to remove your CF card and use a CF card reader connected to your PC, usually via USB. Or you could try a can opener ;-)
BE300 and PC Connect
If you have active sync installed it will stop pc sync from operating properly. If you don't have active sync on your system then go to the below forum and do a search for info on syncing. There are issues with pc sync that have been remedied with some updates.
Hola, me obsequiaron un casio paw1300 3070, la carga esta al maximo y puedo ver hora y fecha, pero las funciones no dan lecturas, altitud, etc, tampoco funciona la luz, cual sera el problema?
English translation;
Hello, they gave me a casio paw1300 3070, the charge is at maximum and I can see the time and date, but the functions do not give readings, altitude, etc., the light does not work either, what would be the problem?
Casio paw1300 3070 Problems
Wie kann ich die Casio TK 2300 umschalten auf Einzelbon
Um die Casio TK-2300 auf den Einzelbon-Modus umzuschalten, befolgen Sie bitte die folgenden Schritte:
- Dr?cken Sie die Taste "Programmierung", um das Programmierungs-Men? aufzurufen.
- Geben Sie das Passwort ein. Standardm??ig ist das Passwort "0000", es sei denn, es wurde zuvor ge?ndert.
- Dr?cken Sie die Taste "1" f?r den Registrierungsmodus.
- Dr?cken Sie die Taste "3" f?r die Bon-Einstellungen.
- Dr?cken Sie die Taste "1" f?r die Einzelbon-Einstellungen.
- W?hlen Sie "Einzelbon" aus, indem Sie die Taste "1" dr?cken.
- Dr?cken Sie die Taste "CA/AT/NS" (Clear All/All Tender/No Sale), um das Programmierungs-Men? zu verlassen.
Ihre Casio TK-2300 ist nun auf den Einzelbon-Modus umgestellt. Wenn Sie einen Artikel auf den Bon legen, wird ein Bon ausgedruckt, der nur diesen einen Artikel enth?lt. Wenn Sie weitere Artikel hinzuf?gen m?chten, wiederholen Sie den Vorgang.
Ich hoffe, das hilft Ihnen weiter!
Weird behaviour on my CASIO WK3500.
.This issue with your CASIO WK3500 keyboard could be caused by a few different things, including:
- Power supply issue: The issue could be with the power supply, and it may not be providing enough voltage to the keyboard when first plugged in.
- Circuit board problem: The issue could be with the circuit board within the keyboard, and it may not be able to start properly if there's a problem with the power supply.
- Firmware issue: There could be a firmware issue that is causing the keyboard to not start properly, which could be resolved by updating the firmware.
- Electrical interference: There could be electrical interference in the area that is causing the keyboard to behave erratically.
