20 Most Recent Casio Lighted Keyboard LK90STADMC Questions & Answers
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Casio Lighted... | Answered on Apr 10, 2017
Yes it could be. Drop voltage adapter can cause power/pre-amp not work properly, but still can power up the lights.
There maybe power supply circuit failure inside LK45 and also power-amp problem.
Casio Lighted... | Answered on Sep 03, 2015
Casio AD-12 for my country with 240V
You may use any 12V 1A AC Adaptor that has the same DC jack provided the center is NEGATIVE. Most common generic AC Adaptors are Centre POSITIVE.
So cut DC end of the wire and solder them in reverse and insulate with tape and it will work.
Casio Lighted... | Answered on Aug 03, 2014
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Casio Lighted... | Answered on May 10, 2011
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD or call casio and explain to them what happened and see if they can help :) Steven.
Casio Lighted... | Answered on Apr 16, 2010
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Casio Lighted... | Answered on Jan 17, 2010
did it come with a driver cd? if so load the drivers for it. if not then you would need to go online and download the drivers for that, and make sure that you put the in the model # of your casio light up keyboard.
Casio Lighted... | Answered on Jan 06, 2010
You can use FL studio it's easy to adjust and easy to work with. Also you can find more help then maybe any other software out there. Also you can find instructions on Youtube how to hook it up. Cake walk is another one, I think adobe audition can too use to be Cool Edit. You can try pro-tools but it's difficult, at least for me it was and finally Sony Acid does it too. Well good luck.
Casio Lighted... | Answered on Nov 06, 2009
i think your keyboard have a lose power
Casio Lighted... | Answered on Aug 31, 2009
The format of song is not supported by the the card . You need to convert to the format supported by the card. ALso the location where it should be placed in the card .
Casio Lighted... | Answered on Feb 03, 2009
Anvil Studio is an easy way to prep midi files for keyboard use, save channels 3 & 4 "left & right" in Midi 0 format and it will light the keys properly. Keep your file size under 80k!
Casio Lighted... | Answered on Dec 22, 2008
If you lucky, the power jack may be at fault since it switches from external to internal battery, but most likely the internal supply is what's damaged... IC regulator possibly. A quick voltage check with a volt meter at the power leads on the main board will verify battery or xfmr supply voltage, if voltage is present then look in close proximity for an IC regulator and check for an output.
Music Logo
34 questions posted
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
smf converter wk 500 exist
  • Music
