20 Most Recent
Hobart 84181-d Buffalo Chopper Mixer Cutter Grinder Questions & Answers
Hobart mixer grinder 1532 keeps blowing fuses
depending on the age and use, the problem it that when the motor stops the amerture shaft bearings are slight worn, causing it to rub on the magnets and grounding the positive charge to the amerture which will arch and through the breaker. May need to invest in a new grinder.
10/21/2020 1:37:17 AM •
Hobart Saws
Answered
on Oct 21, 2020
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
