20 Most Recent Armstrong Air Conditioner Conditioning Relay 39338c001 9100-212q31p Questions & Answers
How do I work the fuse box that is out by the air conditioning unit
get an electrician
7/14/2015 6:59:56 PM • Armstrong Air... • Answered on Jul 14, 2015
MY ARMSTRONG AIR CONDITIONER LEAKS WATER IN BASE OF UNIT
Your drain line is clogged with algae. unclogged it using solution with sodium hypochlorite or hydrogen peroxide.
11/6/2012 3:16:06 AM • Armstrong Air... • Answered on Nov 06, 2012
What challenge did Lance Armstrong face
Gee, that's a toughie, Bob..... To take performance-enhancing drugs, or not to take performance-enhancing drugs.? .........A* to me
3/14/2018 12:53:30 PM • Armstrong... • Answered on Mar 14, 2018
2answers
Life of niel armstrong
Google him
10/28/2017 4:32:44 AM • Armstrong... • Answered on Oct 28, 2017
ArMstrong model eg6g75dc10-4 serial A11148KNA
That unit is not even listed on Armstrong website.
10/5/2015 11:04:10 PM • Armstrong... • Answered on Oct 05, 2015
Hot water circulation pump not working
Check power to the pump.
10/3/2013 8:56:39 PM • Armstrong... • Answered on Oct 03, 2013
I have an Armstrong Astro 25BS recirculating pump
The most common problem with these circulators is that the stator gets stuck and does not turn.
Sometimes you can take out the four bolts on the corners and pull the motor off. Get the stator freed up again and it will work. Make sure to turn the water off before dissassembling the pump. Hopefully you have valves do you can isolate the pump.
Also check that the impeller has not broken off the end of the shaft, that also happens sometimes.
You can check the cap. with an OHM meter by switching the terminals with the test leads and the resistance should count down to zero with each switch of the leads on the terminals...if not it is bad, but replacement of the cap. may not fix the pump usually it is a secondary failure...
If you can't get the pump ot work after taking it apart and making sure it turns freely then I would replace the pump.
Heatman101
12/29/2009 2:59:14 PM • Armstrong... • Answered on Dec 29, 2009
How to wire to 120v and thermostat on a armstrong
A line voltage thermostat is just like any other type of switch, except that it's controlled by temperature.
Just wire the 120vac to the pump, but interrupt the hot (black) wire with the thermostat.
Let me know if you need more help.
10/30/2009 5:46:08 AM • Armstrong... • Answered on Oct 30, 2009
Armsrtong 1/12 horse pump noise
I bled air from the rads attached to the system and now the noise is gone from my circulator pump
12/4/2008 10:41:51 AM • Armstrong... • Answered on Dec 04, 2008
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
2answers
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM • Plumbing • Answered on Oct 19, 2023
My Mirolin bath drain stopper had a spring, which went down the drain when I removed the stopper to clean. Now I'm not sure how the new spring I bought goes back on.
This seems like a system which is proprietary to them, so best to ask their Support staff https://mirolin.com/contact-us/ You could have retrieved the old spring with a flexible magnetic reach tool. https://www.google.ca/search?q=magnetic+pickup+tool https://www.google.com/search?q=Mirolin+bath+drain+stopper ..
10/10/2023 11:30:47 PM • Plumbing • Answered on Oct 10, 2023
Kitchen sink hose broken button nozzle
9/14/2023 5:02:50 AM • Plumbing • Answered on Sep 14, 2023
How do i fix getting water to come out of the faucet ?
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
9/12/2023 6:09:20 AM • Plumbing • Answered on Sep 12, 2023
Armstrong Air Conditioner Conditioning Relay 39338c001 9100-212q31p Logo
9 questions posted
Top Armstrong Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Armstrong Plumbing
  • Armstrong Plumbing
Most Popular Question
work fuse box out air conditioning unit
  • Plumbing
