20 Most Recent
Miller 907175 Welder Generator Perkins 404D-22, 33 HP Questions & Answers
Is there a operation manual for Miller and falls ATS
This manual is all I could find.
Instructions and Parts List for Setting Up and Operating Millers Falls Langdon Acme Mitre Box, Langdon Mitre Box : Form No. M709 : Millers Falls Co. : Free Download, Borrow, and Streaming : Internet Archive
I also found a few results on the web for "miller and falls generator automatic transfer switch". One of the results is a 240V Automatic Transfer Switch by Millers Falls that can be used with GSD7500 & GSD9000 Series Diesel Generators . This switch can be wired directly to the house or workshop mains power fuse box. In Automatic mode, the switch will automatically start the generator if mains power fails for whatever reason. Once the generator is up to full speed and generating voltage at 50Hz, the switch will feed the power into the required load point. When mains power is restored, the ATS will transfer load from the generator back to mains power then shut down the generator. This same function can also be performed in manual mode if required. The wiring of the ATS must only be performed by a licensed electrician. The solenoid operating mechanism of the ATS ensures a high-speed transfer of loads between alternate sources of power, regardless of current draw. These ATS transfer boxes are available in 3 models to suit Millers Falls GSD7500 & GSD9000 (silenced & open frame) diesel generators, GSD13000 diesel generators (silenced & open frame), GSC12000i-Y & GST11000A petrol generators
10/26/2023 1:42:37 PM •
Miller...
Answered
on Oct 26, 2023
Kubota f3060 How do you release the pto to allow removal of the front mower deck
Releasing the PTO (Power Take Off) on a Kubota F3060 tractor to allow removal of the front mower deck can typically be done by following these steps:
- Park the tractor on a level surface and engage the parking brake.
- Locate the PTO engagement lever, it's usually located near the operator's seat or on the right side of the tractor.
- To release the PTO, move the engagement lever to the "disengaged" position.
- Once the PTO is disengaged, you should be able to remove the mower deck.
- To remove the mower deck, locate the lift lever, which is usually located near the operator's seat, and raise the mower deck to the highest position.
- Locate the deck attachment points, they are usually located on the front and rear of the deck.
- Remove any pins, bolts or clamps that are holding the deck to the tractor.
- Carefully remove the deck from the tractor.
It's important to follow the manufacturer's instructions and use the right tools and equipment when working on the machine. If you are not familiar with the mechanical systems, it's best to take the machine to a qualified Kubota repair service center, they will be able to diagnose and fix the issue.
1/22/2023 10:31:59 AM •
Miller...
Answered
on Jan 22, 2023
Welder wiring diagram
The number and location of connection points on a Miller welder when removing the welder and motor from its casing will depend on the specific model and year of the machine you have.
Here are a few things you can try:
- Check the manual of the welder, it should have a wiring diagram that shows the number and location of connection points on the welder.
- If you don't have the manual, you can find wiring diagrams for most Miller welders on the Miller website, you can download it from there.
- If you are not able to find the wiring diagram for your specific welder model, it may be necessary to contact Miller Electric and request a copy.
- If you are not familiar with reading wiring diagrams or if you are not comfortable working with electrical equipment, it is best to take your welder to a qualified Miller Electric welder repair service center, they will be able to provide you with the necessary information and help you troubleshoot the issue.
Please note that some models may have different ways of wiring, it's important to refer to the manual or consult with the manufacturer for further information.
1/22/2023 10:00:51 AM •
Miller...
Answered
on Jan 22, 2023
I have a 1995 miller legand gas welder How do i clean Sliprings and where are the sliprings located on onan engine
To clean the slip rings on your 1995 Miller Legend gas welder, you will need to follow these steps:
- Locate the slip rings on the Onan engine. They are typically located near the rotor of the alternator, on the end opposite the drive shaft. They will look like small, cylindrical pieces of metal.
- Turn off the welder and disconnect the power source.
- Use a wire brush to clean the slip rings by gently brushing away any dirt, debris, or corrosion. Be sure to brush in the direction of the rings' rotation.
- Use a clean rag or compressed air to remove any remaining debris.
- Reinstall the brushes and check that they are making good contact with the slip rings.
- Turn on the welder and check that the machine is running smoothly.
It's important to use caution when cleaning the slip rings, as they are a critical component of the electrical system and can be easily damaged. It's important to check the manual of the welder for troubleshooting steps and also check the warranty of the welder and see if it's still covered by the manufacturer. It's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue if needed.
1/22/2023 9:31:38 AM •
Miller...
Answered
on Jan 22, 2023
MILLER TRAILBLAZER 325 EFI......not getting any power to excel auxiliary outlets.....also cannot find CB5 breaker please help.
If your Miller Trailblazer 325 EFI is not getting power to the excel auxiliary outlets, it could be caused by a few different things.
- Firstly, check the main circuit breaker, often located near the power inlet, it can be tripped and needs to be reset.
- Secondly, check the CB5 breaker, it may be located in the control panel of the welder. Make sure it's not tripped or damaged. If it's not found, please refer to the manual of the welder or consult with the manufacturer as the location may vary depending on the model.
- Thirdly, inspect the wiring and connections for any damage or lose connections, and check to make sure all connections are tight.
- Lastly, the issue could be with the electronic control module (ECM) or a problem with the alternator. It's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue.
1/22/2023 9:21:55 AM •
Miller...
Answered
on Jan 22, 2023
Miller duop welder no arc
If you have checked the fuses, brushes, continuity, and slip rings and still have no power to the rear slip ring, there could be a problem with the wiring or connections in the welder. Some things to check include:
- Inspecting the wiring for any damage or lose connections
- Inspecting the connections for any corrosion or damage
- Checking the terminals for tightness
- Inspecting the generator for any damage or issues
- Checking the voltage regulator to ensure that it is functioning properly
Additionally, it's also possible that the problem could be with the generator itself or the alternator, if the generator is not producing enough power, that could affect the rear ring.
It's highly recommended to take your welder to a certified Miller Electric welder repair service center, they will be able to diagnose and fix the issue. They have the right tools and knowledge to troubleshoot the problem. It's also important to check the manual of the welder to check if there are any other troubleshooting steps that you can follow.
1/22/2023 9:14:54 AM •
Miller...
Answered
on Jan 22, 2023
How do i excite the generator on a miller airpac
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
3/1/2015 9:16:58 PM •
Miller...
Answered
on Mar 01, 2015
