20 Most Recent
Compaq AlphaServer 1200 Questions & Answers
Getting an error on console which repeats fairly
"The "carrier check" means that you have a network problem or a network
transceiver or a transiever cabling problem. The Carrier Sense Multiple Access with Collision Detection (CSMA/CD) protocol senses the network carrier as part of the IEEE 802.3 communications signalling, and your configuration is reporting an error.You have a network problem, in other words.Please contact your hardware support organization, as it would appear that you have a network problem, a network transceiver configuration or hardware problem, or a transceiver
cabling problem."Copied from here
http://h71000.www7.hp.com/wizard/wiz_7105.htmlIs relevant though.
11/12/2013 2:29:25 PM •
Compaq...
Answered
on Nov 12, 2013
WHERE IS MY QUESTION AND WHY HASN'T IT BEEN
Your question may have been removed because of inappropriate language (intended or mistyped), or spam, or illegal, or irrelevant. No need to get mad. People will try to answer it if they find enough information to identify the problem, or if they are knowledgeable, or if they find the time. etc...
11/10/2013 2:09:38 PM •
Compaq...
Answered
on Nov 10, 2013
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
