20 Most Recent Zanussi ZDQ695 Electric Double Oven Questions & Answers
I have a Zanussi zdq695 built in double-oven. The
probably a failed heating element . I just decided to change all of mine cos after a few years they dont get as hot
2/3/2018 11:14:07 AM • Zanussi ZDQ695... • Answered on Feb 03, 2018
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens. Most I can do for you is to provide you some websites selling parts for zanussi: ovens Official Zanussi Site Parts Accessories for Appliances Zanussi Cooker Oven Shop Zanussi Cooker Oven Shop Find Zanussi Spares and Accessories Zanussi Cooker Oven Spares
10/25/2015 9:27:23 PM • Zanussi ZDQ695... • Answered on Oct 25, 2015
I cannot reset the timer
press 1st button together with 2nd last button together with last button at the same time
8/3/2012 9:52:21 PM • Zanussi ZDQ695... • Answered on Aug 03, 2012
I'm the new house owner & there's no manual for
Download the manual from the following link. http://dl.owneriq.net/d/d9667099-caed-48b2-8424-f0d91139a9ec.pdf or go to following link http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html
Both are same links.
8/30/2011 1:58:05 PM • Zanussi ZDQ695... • Answered on Aug 30, 2011
I want to change the
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
7/24/2011 7:11:26 PM • Zanussi ZDQ695... • Answered on Jul 24, 2011
My oven has a rattling sound coming from a fan
The fan you refer to is the external cooling fan, if the oven is built ijn, you will have to remove it from the housing to access the fan, and then remove the top cover of cabinet and possibly the rear cover as well.
12/11/2010 6:31:43 PM • Zanussi ZDQ695... • Answered on Dec 11, 2010
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
4/6/2010 6:13:48 PM • Zanussi ZDQ695... • Answered on Apr 06, 2010
0answers
Loose door
Be the first to answer 2/24/2010 6:07:07 PM • Zanussi ZDQ695... • Posted on Feb 24, 2010Be the first to answer
When operating the large fan oven the fan and
Yes Dave there is a circular element round the fan costs about £30 squid from allspares and is dead easy to replace for anyone with a little DIY skill. Simply take old out and retrace your steps to replace new one Good luck. Oh and you must re-set the clock for it to work. No clock-no oven
5/17/2009 4:52:43 PM • Zanussi ZDQ695... • Answered on May 17, 2009
Error code 367Zanussi cooker not working what is the cause of the error code 367
Error code 367 on a Zanussi cooker typically indicates an issue with the temperature sensor or thermostat. When this error occurs, it means that the temperature sensor is detecting an abnormal or out-of-range temperature. Here are some possible causes and steps you can take to troubleshoot the issue:
  1. Power cycle the cooker: Turn off the cooker and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. Sometimes, a simple power cycle can resolve temporary glitches or errors.
  2. Check the temperature sensor: The temperature sensor is responsible for detecting the oven's temperature and sending signals to the control board. It's possible that the sensor has become faulty or disconnected. Inspect the sensor for any visible damage or loose connections. If necessary, consult the cooker's user manual for instructions on how to access and check the sensor.
  3. Inspect the thermostat: The thermostat regulates the oven's temperature. If the thermostat is malfunctioning, it could be causing the error code 367. Look for any signs of damage or wear on the thermostat. If you suspect a faulty thermostat, it may require professional repair or replacement.
  4. Contact customer support: If the above steps do not resolve the issue, it's recommended to contact Zanussi's customer support or a qualified technician for further assistance. They will have the expertise to diagnose the specific problem with your cooker and provide guidance on the necessary repairs or part replacements.
It's important to consult the cooker's user manual or documentation for model-specific troubleshooting steps or error code interpretations. The manual may provide additional information or suggestions for resolving error code 367 on your particular Zanussi cooker.
5/18/2023 2:45:40 PM • Zanussi Ovens • Answered on May 18, 2023
Hi the grill on my zanussi freestanding cooker is not working but the oven and hob are still working and we replaced the element in the grill so it's not that
If you have replaced the grill element and it still doesn't work, there are a few other things you can check. First, make sure that the grill is actually turned on and that the grill control knob is set to the correct temperature. Next, check the grill's thermostat, which is typically located near the grill element. Use a multimeter to check the continuity of the thermostat, as a faulty thermostat can prevent the grill from heating up. If the thermostat is functioning properly, you may need to check the grill's selector switch, which determines whether the grill or oven is used. A faulty switch can prevent the grill from working. Finally, if none of these solutions work, there may be a wiring issue within the grill or in the main control board of the cooker. In this case, it may be best to seek the assistance of a professional technician to diagnose and repair the issue.
2/26/2023 1:11:02 PM • Zanussi Ovens • Answered on Feb 26, 2023
How do I remove my Zanussi ZNM11X built in mircowave oven
  1. Turn off the power to the microwave oven at the circuit breaker or fuse box.
  2. Remove any food or dishes from the microwave oven.
  3. Carefully open the microwave door and remove the screws or clips that secure the microwave to the mounting bracket.
  4. Disconnect the electrical wires from the back of the microwave oven. Be sure to turn off the power before doing this.
  5. Carefully lift the microwave oven out of the wall or cabinet. It may be heavy, so it is a good idea to have a helper to assist you.
  6. Once the microwave oven is removed, you can either dispose of it or store it in a safe place until it is ready to be reinstalled.
1/3/2023 11:24:59 PM • Zanussi Ovens • Answered on Jan 03, 2023
Zanussi ZDQ695 Electric Double Oven Logo
22 questions posted
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Ovens
  • Zanussi Ovens
Most Popular Question
glass door top oven
  • Ovens
