20 Most Recent
Admiral 26 cu. ft. Side-By-Side Refrigerator Questions & Answers
Need a water filter for my ice maker
you can go to any appliances parts store and get an in line filter it in stalls in the incoming water line before it screws on the water valves comes with instructions if you get the kit
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Admiral side by side refrigerator model GS 22X8D3
Greetings,
in most self defrosting refrigerators..when the fresh food is warm, but freezer is ok...the first thing to look at is...a frosted or froze over evaporator in freezer. this is because, the cold air comes from freezer into ff section. it comes in and drops to floor of ff and is drawn back into freezer thru coil and if its frozen,,,no air can circulate...remove rear freezer panel and look for ice blockage
There are several other things. A fan motor not coming on will do this.. a stuck closed baffle in ff section can keep air out. check it and if froze up..there is a reason, and you need to find out why or it will happen again...check heater, defrost thermostat, check defrost control
Fridge is freezing food
you can usually adjust he thermostat inside the fridge.... can be located anywhere. Try checking the manual if you still got it.
