20 Most Recent Compaq NC8000 LAPTOP (PB656US) PC Notebook Questions & Answers
On that model,there are a few things that can cause your problem.None are simple and the most common is the GPU (video chip) has lost contact due to over heating.
The cost of repairing it, if you could find someone willing ,Would be way more than one that old is worth.
Compaq NC8000... | Answered on Jan 29, 2019
Try a sytem restore and bring it back to the time before this happened.
Compaq NC8000... | Answered on Mar 24, 2012
Assuming you have iTunes installed....
Connect iPod, when iTunes opens, you can go to File ---> Add File to Library (or press Ctrl+O), find the music file on your harddrive, highlight, and click ok. You can then manage the id3 tags (Genre, Artist, etc) by right-clicking on the song, and selecting "Get Info"
Hope this helps!
-- RT
PS - Don't forget to vote!
Compaq Computers... | Answered 2 days ago
format data coded not supported
convert it through a converter software . eg,XVID TO VOB.EXE or MPEG it will work
Compaq Computers... | Answered on Apr 10, 2019
Hello Dear,
with this model only AMD Processors are compatible
please check this
https://www.support.hp.com/us-en/document/c01861126
in
Processor upgrade information
Compaq Computers... | Answered on Mar 25, 2019
what Linux
non stated, of 100s.
why post lacking such key facts.
NO PC sated, just a nebuluas complaq.
no OS stated, just linux something
why not ask on YOUR linux forum.
try Ubuntu? yet?
best is to match PC old to Linux old.
but be impossible for me to guess what PC you own.
Compaq Computers... | Answered on Mar 01, 2019
I am pretty sure you can't boot an OS from a USB. Burn the install media to a disc or put it on a spare partition. USB boot is for anti-virus or PC Diagnostic Tools.
Compaq Computers... | Answered on Feb 23, 2019
That sounds like your hard drive may be dead...
Compaq Computers... | Answered on Feb 22, 2019
Xp had a lot of issues with shutdown early on, but they should have been mostly resolved.
1. Make sure windows is up to date, IE all updates.
2. Make sure all drivers are up to date.
3. Run some anti virus/adware/spyware programs, could be something preventing your computer from shutting down.
4. You aren't unplugging and USB/firewire devices without stopping it first are you?
Compaq Computers... | Answered on Jan 05, 2019
If you are more than just a beginner you can attach that drive to your PC and run a drive copy program that will create an exact image of your current drive. Once that is created then you can add the new drive to the computer make sure your system recognizes it and can boot from it. I have done this many times.
Compaq Computers... | Answered on Dec 27, 2018
Lights can come on but your CPU is not booting the Operating System. Can be the Hard drive or windows os.
Compaq Computers... | Answered on Dec 25, 2018
Dead PC, PC fans totally dead
that most times means PSU dead, or shorted modules inside PC> (im sure the power switch wire, to the mobo did not fall off) and the green LED on back of PSU is glowing green , (per manual HP ) means AC power side is good.
SR1200 series desktop made in fact in the Compaq plant in Texas.
2004 newest 2002, oldest.
if the coin cell is that old, it is bad.
none ever last that long; 14 years to 16year old batteries are no good. but a DMM check will not lie to you. 2.9v min, lower bad.
If both fans are dead , the PSU is bad.
in some cases, (no pun) we open the case
power off, (ac cord pulled)
push power on to discharge all caps in the PC,
normally one sees the CPU fan spin for 1 seconded and die. (but that is good PC yours is not)
we remove all power wires from the PSU from it
to HDD, to CD, drives, and to floppy 4 pin power
we do that because shorted devices, cause all PSU to shut down. even in 1/2 of second or LESS.
by design (ATX spec) this prevents fire, in the case/psu.
plug in PC, AC and push power, do fans run now, both must run , not just one fan.
power off again, ac line pulled, push power button again, to discharge things,
now
The once all those pig tails from PSU to THINGS are pulled , but not your MAIN 20 pin connector to mobo
we do what, we remove ram and test each stick 1 by one.
doing same tests, AC line pulled. remove RAM.
but 1 stick reseat it, and test for power on again.
if you have the original DDR memory sticks test them 1 by 1, each. ok>? they can short too. 94c62a99-50e0-4817-b127-42fc295914d0.jpg
Compaq Computers... | Answered on Nov 24, 2018
Compaq DT.
no Desktop stated from 1980s to now. 1000s of models possible.
what model PC is it?
no password type stated there are 6 levels of passwords,
no photo of failing screen shown
no OS stated if it is OS PW.
6 levels are here. some are impossible.
http://pcdied.com/passwords.html
this relic?
Compaq Computers... | Answered on Nov 18, 2018
Most motherboard manuals are available on the internet and are easily found with a simple search.
Compaq Computers... | Answered on Nov 01, 2018
Compaq NC8000 LAPTOP (PB656US) PC Notebook Logo
3 questions posted
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
compaq nc8000 when turn lights come but
  • Computers & Internet
