20 Most Recent
Compaq NC4000 (DG987AABA) PC Notebook Questions & Answers
My HP compaq nc4000 has
it's 14 years old junker PC, COMPAQwhy own it?why run XP , that is what it had in 2003for sure.XP is dead.so is the PC. it has no support at all .It or Its OS. zero.goodwill puts them in the trash.why?because they are cHock-a-block STACKED UP swimming in w7 and newer PC that have real vaLUE.GET ONE.?W95 to XP LOVES TO BSODH3LL GILL BATES, EVEN BSOD HIS ON STAGE. REMEMBER?https://www.youtube.com/watch?v=eKy9fV_zX_oTHE DID THIS 5 TIMES, LIFE IS TOO SHORT FOR THE LIKES OF XP. NOW.TRUST ME....http://www.pcdied.com/XP-sux-sg.html
Wireless connection
You will need to speak to the person in charge of the security enabled network, and obtain the type of wireless security (WEP or WPA) and the password.
You should also determine what security types are supported by your own laptop's wireless connection. If it is an older one, it may only support WEP, and you will be unable to connect to any WPA protected networks.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
