20 Most Recent
KEF Audio KIT100 System Questions & Answers
Thanks ,when i turn on
I can understand sentimental attachment.
The symptom you describe could be something as simple as a "dry" soldered joint but finding and rectifying it, if indeed it is only that, needs a deal of experience and knowledge you clearly do not possess and learning on a treasured item is not advisable because getting it wrong can cause a great deal more trouble.
I suggest you look in your local classified directory for a suitable repair shop - there is usually a few in every locality repairing tv, radio and audio equipment, in-car entertainment and general electronic repairs. Most people doing that sort of work are cheaper than official dealers and use cheaper parts, yet many of them began by working for the bigger brands.
KEF KIT 100 DVD not opening. Display says
Did you get the software update to work? I must be doing something wrong..when I burn the files to a cd-r it says error 4 after the question yes/nowhen i burn them as ISO it says bad discCan't get it to work.. too bad, since the system has great sound!
KEF KIT100 buzzing clicking noise
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Kef kit 100 buzzing popping
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25. I would have all 6 replaced. It is better to run a matched set.
