20 Most Recent Baumatic 18 in. BDW45.1 Built-in Dishwasher Questions & Answers
2answers
E4 ERROR
i have had the same problem,saw this add and got to it straight away,excellent info worked a treat,thankyou very much
10/10/2015 10:45:38 PM • Baumatic 18 in.... • Answered on Oct 10, 2015
Baumatic bdwi649 dishwasher leaking from underneath
what to do depends the source of the problem is. When it leaks from the water supply, then see if tightening it will help. look also for cracks or leaks. If it is the drain, check the fittings and the hose. If it is the unit itself, then you have my best wishes.
4/16/2015 3:16:49 PM • Baumatic 18 in.... • Answered on Apr 16, 2015
How do i replace guide support on top rack as wheels keep falling off
I would check with the repair depot and get the parts that you need. I am unfamiliar with this unit itself. If the unit holding the wheels on is broken, perhaps a plastic screwnail would hold it on.
4/16/2015 3:13:44 PM • Baumatic 18 in.... • Answered on Apr 16, 2015
0answers
0answers
0answers
Door will not shut.No error code.Door keeps springing open!
Hi thereIf this door was mine I would get the dishwasher -doctor to come and fix the door. On the other hand if you have a good friend who likes repairing things he might talk to your machine.kolbrun
2/25/2012 5:59:22 PM • Baumatic 18 in.... • Answered on Feb 25, 2012
How do i remove the door panel
You may not have to, go to www.applianceart.com to see many options that go over your current panel. They also have stainless replacement panels. The only dishwashers that have panels that you can replace are "frame" dishwashers. If you have one of these, there will be two screws on the side of the door that, when unscrewed, release one side of the frame allowing you to slide the panel in and out. If your dishwasher has metal that wraps around the side, you may want to try a vinyl or a stainless steel foil option that wraps over your door around the sides. Also available at www.applianceart.com.
9/2/2011 5:47:03 PM • Baumatic 18 in.... • Answered on Sep 02, 2011
Not cleaning dishes,tablet not disolving
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
3/27/2011 6:37:53 PM • Baumatic 18 in.... • Answered on Mar 27, 2011
No manual for baumatic dishwasher bd 45.1
dishes are left with detergant on them, not ricing properly
3/7/2011 7:02:24 PM • Baumatic 18 in.... • Answered on Mar 07, 2011
Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
51 questions posted
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Baumatic Dishwashers
Most Popular Question
e4 error
  • Dishwashers
