20 Most Recent
Northstar 1999 Cadillac Deville Air Intake 4.6 Seville Questions & Answers
The ignition and good key are good but car is in theft mode
your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.
How do I fix problem code po 322 on my 1999
Setting a code P0322 for missing or erratic 4x reference signal. Also experiencing long crank times.
Tests/Procedures: 1. Check for an erratic signal from one or both of the CKP sensors.
2. Check for a square wave signal at ignition module on the Purple/White wire.
3. Verify the wiring from the ignition module to the Powertrain Control Module (PCM).
P0322 ICM 4X Reference Circuit Malfunction - With Automatic TransmissionPossible Causes Setting Conditions
•Fuel control signal circuit is open
•Fuel control signal circuit is shorted to ground
•IC module has failed
•PCM has failed
DTC P0340 and P1376 not set; engine running; CMP sensor signal detected in the last 4 seconds, and the PCM did not detect any 4X fuel control pulses for 4 seconds.
This code sets in 1 Trip(s).
Can't get the flywheel off of a model
Tap the bolt of the puller while you tighten it, spay some penetrating oil on the shaft and leave it for a while and try again. If that is unsuccessful, apply a little heat to the flywheel and try the above again.
I have a 45920I air
You can use universal pilot valves and throttle control. Shop on ebay or
www.grainger.com. Look closely at the fittings that are required to fit a different valve on your compressor. Most all pilot valves work the same however there are hundreds of fitting combinations. The throttle control is easier because they usually all have 1/8 thread into the pilot. Universal parts cost much less. I would suggest taking your compressor to a shop that specializes on air compressor repair and they could suggest what pilot would work best. Good holidays
