20 Most Recent
Compaq Presario 5000US (D70008-261) PC Desktop Questions & Answers
I'm having video problems with my sr5710f compac
its old and old pc have problems, just like cars.
a desktop
NO OS stated, came with VISTA. (a dead OS now)
no monitor stated,?
series 5000 is obsolete, and near worthless.
the unstated monitor is first.
if the OSD screens is dead?, yes then the monitor the monitor is BAD
all monitors 2000 year and newer have OSD
the OSD is the monitors brain inside
you push the menu button on the front and behold , this.
this pc has onboard GPU/VGA chip (unless upgraded to PCI slot VGA)
a key missing fact if true. (but is possible)
if running and old CRT monitor , do tell which one (model number)
here are all simple tests on that monitor.
http://www.pcdied.com/monitors.html#desktop
How to install an infineon 256mb ram memory
First make sure it's the proper memory for the system. The manual that came with the computer should tell you what kind of memory it takes. If you don't have a manual, go to HP's site and look for that model and get the specs.
Second, you'll have to open the case and remove the memory stick/s that are there. Push down the little tabs at each end and pull the memory out. Then reverse the order to put the new memory in. Be careful--the memory goes in only one way. There is a key slot in the bottom that will enable it to be installed only one way.
A logical question is--why are you installing 256 MB of RAM. That's a very tiny amount. You should be going for the biggest size you can. I wouldn't waste my time on 256 MB unless the system is limiting you.
The monitor keeps clicking off/won't stay on
the wiring's are loose either the power plug is got connected loose at main electric outlet or the monitor wire to the cpu is got loose.reconnect all the wires.first remove all the wires then reconnect each and every wire properly.
check if there is dust got in the wires or in the ports where wires are inserted.
if every this proper still the same problem then its the problem of internal parts like hard disk or ram or any other internal part of cpu is not properly fitted.remove it ad refit then check out.if still the same problem then its the problem of monitor its getting overheated and shutting off.the monitor main board needs rearing.check the monitor by connecting it to other cpu unit and confirm the fault.whether is faulty cpu or monitor.
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
Where do the front usb
Please elaborate your problem providing us with more details and the complete make and model number of the motherboard.
To find where the USB connector is located on the motherboard, look for 5 pairs of pins with a label that starts with
USB,
JUSB,
FRONT_USB, or
F_USB. If your motherboard has two sets of pins, F_USB1 and F_USB2 for example, use the lower number first. (
See attached image)
Hope this solves your problem. Thanks for using FixYa
Where can i find a
All IEEE 802.11b/g standard wireless cards are compatible with any chipset. I have narrowed it down for you though. You can check out the card from the link below.
http://www.atheros.com/pt/AR5007EG.htmIt goes into the PCI-E slot of *********** board. Once you install the card you can download the driver from the atheros site.
Sai.
